You are describing different failure modes on each engine. You have rotten luck.
On this third engine sounds like you have a vacuum or exhaust leak somewhere causing the O2 to read lean and adjust for it by dumping to much fuel in it. I bet your oil smells like fuel now.
Did you use the same engine harness or is it different? If there no leaks then it may be electrical but i doubt it.
