I have a few codes. I replaced plugs and wires just over a month ago and the old plugs were pretty rough looking. I got a few codes that came up afterwards.
P1404
"EGR valve stuck open. While monitoring the EGR valve pintle position the ECM detected the closed position sensor voltage higher than the learned closed position voltage.
Probable cause:
- Failed EGR valve
- Carbon blockage of pintle"
I cleaned the EGR today so that will hopefully work correctly now.
P0243
"Turbo/Supercharger wastegate solenoid a fault.
The ECM has detected a signal outside paramaters on the wastegate solenoid circuit.
Probable cause:
- Open or short circuit condition
- Poor electrical connection
- Failed wastegate solenoid"
P0304
"Cylinder 4 misfire.
The PCM monitors the crankshaft apeed and has detected a misfire condition.
Probable cause:
- I have a few codes. I replaces plugs and wires just over a month ago and the old plugs were pretty rough looking. I got a few codes that came up.
P1404
Probable cause:
- Failed EGR valve
P0243
Probable cause:
P0304
Probable cause:
- Ignition system fault-spark plug(s), ignition wires, coil
- Vacuum leak
- Injector fault
- High or low fuel pressure"
P0300
"Cylinder misfire detected- random cylinders
The PCM
P0300
The PCM monitors the crankshaft speed and has detected a miafire condition.
Probable cause:
- Vacuum leak
- Injector fault
Any ideas of what the issues could be? I feel like there is something going on that if fixed will knock more than one of the above problems out.
