Thread: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
Results 1 to 17 of 17
  1. #1 Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    Banned
    Apr 2013
    Mesa,AZ
    Today i got a clean 2000 gtp one owner, had cracked heads.
    Now i have a 97 Black GTP and was going to put the engine offf of that into the white one.
    Is it a direct swap?
    Will i have any problems with different wiring issues?
    What do you reccomend replacing on my motor before i do install it into the white one..
    Any input appricated, thanks
    Ps i have planned on to replaced rear main seal, and water pump, spark plugs. And hopfully a set of speedy daddy headers
  2. #2 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Should work fine. Change the oil pan gasket/tray when it's out.
    I'm not sure if the wiring would be different between a 97 and 00. Someone else will probably chime in.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  3. #3 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    Banned
    Apr 2013
    Mesa,AZ
    I have the oil pan gasket ready to be installed, along with new motor and tranny mounts, and new radiator
  4. #4 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    If you want direct bolt in use the 00 sc
  5. #5 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    Banned
    Apr 2013
    Mesa,AZ
    Is there any advantages to useing the 00 SC or any disadvantages?
    So use the SC off the 2000 and its a direct swap?
  6. #6 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    you need to swap the tb, injectors and maybe a few other sensors, and the alt and its bracket. you just take the parts from the old engine and put them on the donor engine.
    the gen 3 sc was used from 97 - 03
  7. #7 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    I meant leaving the tb on the sc. Injectors and sensors are the same. Alternator bracket can be left alone if you want
  8. #8 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    pretty sure the alt and bracket wont work. just use what ever was on your old engine, put it on the donor. the tb is different for sure, as is the maf. 97, and 98 have the cast elbow on the bracket, and the alt had a different plug on it so use your cars alt and bracket.
    97 and 98 the same maf, 2000 not the same at all. swapping your tb and its sensors is all you need to do for that.
  9. #9 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    Alt and bracket shOuld work. They have the same plug
  10. #10 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    Banned
    Apr 2013
    Mesa,AZ
    So swap out the throttle body & Supercharger from the 2000 engine and bolt on the 97' engine
    And possibly the alternator & bracket?
  11. #11 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    i could have sworn i saw threads where the plug wont fit. and who wants a 97,98 style alt bracket?
    the threads i saw this in were ic threads, where they changed to the 99 up alt and bracket to make room for the ic hoses. everyone seems to use the alt its plug and the 99 up bracket.
    i could be wrong, its happened in the past lol
  12. #12 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    Quote Originally Posted by GTPlzz View Post
    once you take the sc off both engines, use the one that has the best looking rotor coating left.
  13. #13 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    The 97 had a dumb vacuum tree on the sc that's why I said use the 00 the altbracket is up to you. Id swap it along with new coolant elbows and lim gasket. The plug on my 98 is the same as my 04 and 99
  14. #14 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    Banned
    Apr 2013
    Mesa,AZ
    Yeah i just swapped out those coolant elbows to the metal ones.
    I was thinking about doing LIM and possible head gaskets just to make sure its gunna be good for a while
  15. #15 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    leave the heads alone, if the 97 has plastic lim gaskets change them. do the oil pan and rear seal too if it looks wet.
  16. #16 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    Definitely leave the heads alone. Now is a good time to cam it while the motors out
  17. #17 Re: Will a 97 gtp motor fit into a 2000 gtp as a direct swap?
    May 2013
    Cuyahoga Falls,Ohio
    Do not help this guy with anything...GTPlzz..he sent me faulty torn cone speakers.
    He scammed me out of money and now wont return my calls or texts..
    DO NOT BE NICE to him !! He's an asshole,a thief and a liar !!!
  1. 03 engine into 02 GP... Direct swap?
    By jonygtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2012, 08:52 AM
  2. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
  3. Building a motor for my 2000 GTP
    By ls1camino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2011, 07:57 AM
  4. Replies: 0
    Last Post: 10-07-2011, 06:53 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
