Thread: Aeroforce Scan Gauge
Results 1 to 20 of 28
jacobmh27 Aeroforce Scan Gauge 08-25-2008, 09:18 AM
IndeedSS Re: Aeroforce Scan Gauge 08-25-2008, 02:16 PM
FoSHO99 Re: Aeroforce Scan Gauge 08-25-2008, 05:29 PM
jacobmh27 Re: Aeroforce Scan Gauge 08-26-2008, 06:38 AM
IndeedSS Re: Aeroforce Scan Gauge 08-26-2008, 07:41 AM
jacobmh27 Re: Aeroforce Scan Gauge 08-26-2008, 08:13 AM
GeddyLee Re: Aeroforce Scan Gauge 08-27-2008, 10:49 AM
IndeedSS Re: Aeroforce Scan Gauge 08-27-2008, 12:28 PM
GeddyLee Re: Aeroforce Scan Gauge 08-27-2008, 01:24 PM
IndeedSS Re: Aeroforce Scan Gauge 08-27-2008, 01:44 PM
blowfishRus6 Re: Aeroforce Scan Gauge 08-28-2008, 01:45 PM
IndeedSS Re: Aeroforce Scan Gauge 08-28-2008, 02:05 PM
Sabrewings Re: Aeroforce Scan Gauge 08-28-2008, 04:37 PM
IndeedSS Re: Aeroforce Scan Gauge 08-29-2008, 07:20 AM
Sabrewings Re: Aeroforce Scan Gauge 08-29-2008, 04:10 PM
blowfishRus6 Re: Aeroforce Scan Gauge 08-28-2008, 04:52 PM
GTPJIM Re: Aeroforce Scan Gauge 10-13-2013, 01:39 AM
  1. #1 Aeroforce Scan Gauge
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I am having a problem with the new gauge. When I turn the car off and on again I have to unplug the OBDII port and plug it back in to get it to come on. Do I have to hook up the Acc Power to it for it to work right? And I noticed my TOrque is really up there is it really that reliable. Cause I am reading like 500 FtLbs No Way.. I know that is wrong my HP seems to be on though. I do like it. I have to get my Pod now to install it right. I am also looking at my knock and it shows like 3 at wide open. Is that right?
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: Aeroforce Scan Gauge
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by jacobmh27 View Post
    Because of the bcm mine has a 5 second delay before starting up. Are you leaving it plugged in long enough from a cold start for it to start up on it's own? Does it shut off after a few seconds when you turn the car off?
    I think the torgue reading being off is a know issue.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Aeroforce Scan Gauge
    Jan 1970
    Maquoketa, Iowa
    What year of car? I had to run an accessory power because my 2001 doesn't have a pin on the OBD2 for the gauge to power.
    The hp/torque might be off, if you really want to be close then adjust the altitude you have it set on and such.
    All stock gp's will read a few degrees of kr from factory. 3 isn't bad but its acceptable when your not modding and making more power than stock.
  4. #4 Re: Aeroforce Scan Gauge
    Naugatuck CT
    it is an 01 and the Gauge will turn on then when I shut the car off A few seconds later the Gauge will shut off then when I start the car the gauge 2 lights just blink till I unplug the gauge and plug it back in
  5. #5 Re: Aeroforce Scan Gauge
    St Louis MO
    weird...My two annunciator lights flash a couple of times when I start my car but then a few seconds later the wlecome screen pops up.
    Sounds like you may need the addtional hot wire.
    Perhaps shooting Aeroforcetech an email may get you a better answer.
    2010 Camaro SS LS3
  6. #6 Re: Aeroforce Scan Gauge
    Naugatuck CT
    Well they say in the Manual that 96 to 03 most need to have the Extra Power wire for Pontiacs I do not know how true it is but I may write them. Does our car support Oil Pressure I do not think that it does I am going to order 2 other gauges today A manual Boost gauge and an Electric Oil Pressure I think.
  7. #7 Re: Aeroforce Scan Gauge
    St Louis MO
    No the PCM doesn't have an output for oil pressure that the scan gauge can pick up. My car has an oil pressure guage stock. While I know know the real numbers, I do look at the needle to make sure it's where is supposed to be.
    2010 Camaro SS LS3
  8. #8 Re: Aeroforce Scan Gauge
    St. Louis Mo.
    You have to have the power hooked up to it. You can not rely on the OBD2 port to power the gauge, plain and simple. Once you have the wiring hooked up to an accessory, ie one that turns on when the car is turned on and then powers off when the car is turned off. If you are removing the OBD2 plug when the gauge is active, you run a major risk of messing up the unit.
    Make sure you have the power setup and connected to the additional wiring plug provided. And then you have to also REMOVE the red cap from the back of the unit. I left mine on and I got all kinds of security warnings, until I removed it and it functioned normally.
    Once you start your car, it will take approx 5-10 seconds for the Gauge to power up, and you will see the two LEDs light up and the prompt on the main screen and then you be taken into the gauge and you can configure it from there.
    As for the Analog stuff, there is a bunch of programming you have to do for it and you need to purchase one of Aeroforce's sender units to complete the setup. I personally just a run a seperate OP gauge along with my Boost gauge, Tranny Temp Gauge and my A/F Gauge ontop of the Aeroforce.
    I hope that helps.
    James Shafer
    St. Louis MO
  9. #9 Re: Aeroforce Scan Gauge
    St. Louis Mo.
    Well the A/F LED gauge is basically useless. But the Aeroforce's A/F Millivolts reader is pretty darn spot on. It mirrors the LEDs pretty well, but gives a better number value to what the LEDs try to show. And no I have not gotten a WB A/F yet, though I am diggin' Rick Cobalt WB A/F setup
    James Shafer
    St. Louis MO
  10. #10 Re: Aeroforce Scan Gauge
    St Louis MO
    Quote Originally Posted by GeddyLee View Post
    A/f mV of what? Your Narrowband as in O2's mV verus a WB that reads in a ratio?
    2010 Camaro SS LS3
  11. #11 Re: Aeroforce Scan Gauge
    St. Louis Mo.
    Quote Originally Posted by IndeedSS View Post
    I guess *shrugs* I am just going by what the Aeroforce tells me in O2 Millivolts. It is basically a digital read out of the LEDs. It puts a physical number to the nice flashy LEDs
    Did I explain that any better??
    James Shafer
    St. Louis MO
  12. #12 Re: Aeroforce Scan Gauge
    St Louis MO
    No, because O2's read in mV, as in say, 960mv may or may not be close to 10.6:1 AFR (example only since accuracy of a NB is questionable, varies from sensor to sensor and changes with temp and age). But if you have no WB hooked up to your A/F gauge how do you know what the air fuel ratio is. Granted the Aeroforce will be accurately reading your narrowband via the PCM. Or are you talking about Commanded AFR, which, unless your tune is spot on, may or may not be the same as your AFR that your A/F gauge with a WB attached would read.
    I'm just trying to understand how you hooked up an A/F gauge to your Aeroforce and have it displaying an AFR, unless it is a guessing AFR. Thought maybe you have a shortcut or secret, that you should share.
    2010 Camaro SS LS3
  13. #13 Re: Aeroforce Scan Gauge
    Donating Users blowfishRus6's Avatar
    g.a.
    has anyone had any play time with this..
    MSD DashHawk Vehicle Information Display - PFYC
    can the aeroforce do a cylender misfire cycle?? would that be a pretty handy feature to have?? with out a tunner there is not much i could do about it tho.
    just wondering what yall thought about it
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  14. #14 Re: Aeroforce Scan Gauge
    St Louis MO
    Quote Originally Posted by blowfishRus6 View Post
    It will display total misfires. You can go to Interceptor OBD2 data stream gauge and scan tool by Aeroforce Technology and download the manual. It lists the available options.
    2010 Camaro SS LS3
  15. #15 Re: Aeroforce Scan Gauge
    Barksdale AFB, LA
    The Aeroforce can list your misfires by individual cylinders all at the same time.
    2009 Subaru Impreza WRX STI
  16. #16 Re: Aeroforce Scan Gauge
    St Louis MO
    Quote Originally Posted by Sabrewings View Post
    How does it fit all 6 cylinders on that little display at the same time?
    I can't see misfires anyway since my P0300 has been disabled, but just in case I need to re-enable, how do you do this?
    2010 Camaro SS LS3
  17. #17 Re: Aeroforce Scan Gauge
    Barksdale AFB, LA
    It lists them like this...
    Cylinder #1: 0
    Cylinder #2: 0
    Cylinder #3: 0
    Cylinder #4: 0
    Cylinder #5: 0
    Cylinder #6: 0
    And I think the last couple lines are all "X" because it's also available for V8s. It can fit it all just fine...
  18. #18 Re: Aeroforce Scan Gauge
    g.a.
    okay thats cool. i was just wondering if that other guage was any better. not by the looks of it tho
    its slow.
  19. #19 Re: Aeroforce Scan Gauge
    Dec 2012
    Canada
    I am going to be adding an Aeroforce Gauge to my 02 GTP, can I get the power required through the cigarette lighter by the way of a plug?
  1. Aeroforce scan gauge performance mode
    By spidamanSS in forum General Tech Discussion
    Last Post: 07-02-2008, 02:25 PM
  2. Aeroforce gauge...
    By duane9586 in forum General Tech Discussion
    Last Post: 07-01-2008, 01:32 PM
