Thread: Loud Knocking/Ticking sound when Idle or Under Load [Help and Recommendation Please]
Results 1 to 7 of 7
  1. #1 Loud Knocking/Ticking sound when Idle or Under Load [Help and Recommendation Please]
    Jul 2010
    Hackensack, NJ
    Where do I start...
    So I have a 05 Impala that I topswapped to a genV blower and SD headers. About a week ago I started driving with my windows down and music off () and i noticed a faint ticking sound coming from the engine area. I didn't pay it much attention at first, however, as the week progressed It lingered in the back of my mind and I kept listening for it. Wednesday or Thursday morning I got in the car started it and attempted to reverse. The car did reverse but it felt like it was sputtering a bit. Anyways, I put it in drive and sputtering went away and drove normal. In the evening I got in the car started it after it being off all day. I realized that the ticking sounds got louder. I had a moment and just drove home. When i got home and was in the parking garage, I guess the closed space amplified the sound more to where It was sounding like a rod knock. I parked, popped the hood up and grabbed my mechanic stethoscope. It was dark so I just left it.
    Next day I started the car and it sounded like loud knock sound in the block while idling and while engine under load.
    Today, off from work, I decided to use the stethoscope and do some more searching. I turned the car on this morning and got 3 codes. P0122, P306, p0641. So TB sensor low circuit, misfire cylinder 6, and reduced engine power code (according to google). After probing, the knock seem to be the loudest around the rear valve cover cylinder 6.
    This lead me to remove the rear valve cover. When I did that I found that the farthest right valve rocker arm had a lot of play between the pushrod and the spring (even though the screw holding the rocker to the head was still torqued). I removed the screw and lifted out the rocker, pushrod and screw to visually inspect. The rod was not bent. .
    I then decided to remove the next one over rocker arm,pushrod assembly so i could do a comparison. What I found was that the spring supporting that one was sitting lower when being compared to the first rocker arm that I removed. I also noticed that the pushrod was sitting higher in this one when being compared to the pushrod in the first rocker arm removed. So basically, pushrod on the problem rocker was sitting lower than all other pushrods on the rear head and its associated spring was sitting higher than all other springs on the rear head. Example video ------> http://www.youtube.com/watch?v=uNWhIjA9c6A
    I have been scratching my head at this all day. Could it be a stuck lifter, or......?
    I don't have a video right now, but it literally sounds like this http://www.youtube.com/watch?v=x-6Aj...e_gdata_player
  2. #2 Re: Loud Knocking/Ticking sound when Idle or Under Load [Help and Recommendation Plea
    where the cam is will make the push rods higher or lower. what you want to do is bring cly 6 up to top dead, the valves should match then.
    the spring its self being higher dont sound right tho.
  3. #3 Re: Loud Knocking/Ticking sound when Idle or Under Load [Help and Recommendation Plea
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    with the top swap, did you get it tuned? have you been monitoring for KR?
  4. #4 Re: Loud Knocking/Ticking sound when Idle or Under Load [Help and Recommendation Plea
    Jul 2010
    Hackensack, NJ
    @Scotty I thought it was weird that it was sitting little higher as well. @orange yes, i did tune and ive been watching KR
  5. #5 Re: Loud Knocking/Ticking sound when Idle or Under Load [Help and Recommendation Plea
    Aug 2012
    Chandler, AZ
    How's your oil level and pressure?
  6. #6 Re: Loud Knocking/Ticking sound when Idle or Under Load [Help and Recommendation Plea
    Jul 2010
    Hackensack, NJ
    oil level and pressure is also fine. running mobil 1 synthetic
  7. #7 Re: Loud Knocking/Ticking sound when Idle or Under Load [Help and Recommendation Plea
    SE Level Member a97GTP's Avatar
    Jul 2013
    Priest River, Idaho
    If this Doesn't Help it could possibly be a Collapsed Lifter
    Black 1997 Pontiac Grand Prix GTP, 3.4" Pulley, P&P Supercharger, Modified LIM, VS-Cam, 105# Springs, FWI, Ported Rear Manifold, ZZP P-LOG, EGR Delete.
    ^^^L36 Top Swap^^^ R.I.P. L67 197,894
  1. engine ticking/knocking and dies
    By mzbonski in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2013, 02:28 PM
  2. Straight pipes sound bad, loud ticking when accelerating
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 04-12-2012, 12:05 AM
  3. Knocking or tapping loud!
    By GotThatPower in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2012, 11:30 PM
  4. Missing or Knocking under a load, HELP!!
    By Morris 04 GTP in forum General Tech Discussion
    Last Post: 06-14-2010, 11:16 AM
  5. Ticking/knocking sound in engine compartment
    By 200GpGt in forum General Tech Discussion
    Last Post: 04-17-2010, 03:54 PM
