Thread: Metalic Tick by Crankshaft pulley after engine swap
Results 1 to 4 of 4
  1. #1 Metalic Tick by Crankshaft pulley after engine swap
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    After swapping out the blown L67 with a junkyard L67 that had 89k on the clock there was a distinctive tapping noise coming from what I thought to be the crank pulley or something very close. I wanted to go have a mechanic listen to it before I pulled it and send it back to the junkyard but It died on me half way there and wouldn't start back up. It still cranks, no holes or oil leaking from the block. Im almost positive it never lost oil pressure (going by the dummy light) now what? Im loosing my patience and motivation to keep fixing this car. What do you guys think? Crank sensor? Harmonic balancer? main bearing?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Metalic Tick by Crankshaft pulley after engine swap
    Maybe the balancer is broken, see if its cracked.
    But its kinda hard to say what happened.
  3. #3 Re: Metalic Tick by Crankshaft pulley after engine swap
    Pull the balancer, w/o knowing what kinda reason it was in the yard. I'd guess the belt wrapped or something and either bent a ring of the balancer or the sensor got beaten up.
    I had one that came out of a horrible accident with 40K on it. Oil pan was dented, AC bracket broken.. what I didn't see was part of the crank sensor had cracked and when I decided to wash it.. stalled and wouldn't restart until I found and installed a fresh sensor.
  4. #4 Re: Metalic Tick by Crankshaft pulley after engine swap
    Nebraska
    Well I should have mentioned the engine came out of a totaled 2004 impala I was told It ran before they pulled it. This engine also had a bad dent in the oil pan I had to replace it.
  1. Harmonic Balancer Crankshaft Pulley
    By sicayan in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-21-2011, 11:10 AM
  2. Engine Tick Help!
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2011, 09:46 PM
  3. Slight problem..Crankshaft Pulley puller
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2009, 08:31 PM
  4. Crankshaft Pulley MisAlignment
    By Mikey2769 in forum General Tech Discussion
    Last Post: 06-29-2009, 11:49 PM
  5. Crankshaft Balancer/Pulley
    By marcheer in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-07-2009, 06:46 PM
