Thread: exhaust help.
Results 1 to 5 of 5
  1. #1 exhaust help.
    Mar 2013
    amherst
    What size adapter do I need for the 3" sd header dp to the exhaust a few inches before the cat ? Ive been everywere and eveyone has diffrwnt sizes. I thought it was 3" to 2.5 but everywere says diffrent
  2. #2 Re: exhaust help.
    The SD header dp will bolt directly to the factory cat back, if you cut off the flange the stock exhaust is 2.25".
  3. #3 Re: exhaust help.
    Mar 2013
    amherst
    I'm using stock cat and a few inches before it . So the 3" will bolt up to the 2.25? And would a 3 inch to 2.5 reducer work if I usr a band clamp over 2.25. Like 2.5 to 2.25 work ?
  4. #4 Re: exhaust help.
    Your thinking way to hard about this.
    As long as the exhaust is stock the SD will bolt up to it.
    You need 2 2.25" bandclamps
    And 2 3" bandclamps
    04 Comp G.
  5. #5 Re: exhaust help.
    Mar 2013
    amherst
    I think I'm explaining it wrong. I already have the ubend delete . So um not using the 3" one with the ubend delete or the o2 port. So I'm just going from the 3" peivce that bolts up to the flex to the stock piping. Its a .75 diffrenxe ? That won't matter ?
  1. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2009, 02:43 AM
