Thread: Lets play "Diagnose Joshs' car" :)
Results 1 to 12 of 12
  1. #1 Lets play "Diagnose Joshs' car" :)
    Sep 2013
    Menomonie
    Ladies and Gentleman,
    Hi. I am new to the forum but have spent many hours reading on here. Here is a quick back ground on my car. So you know what the situation is. Picked up a loaded 2000 Grand Prix GTP Coupe two years ago. First year I owned it, it was rather trouble some. Stage one of repairs consisted of: Rack and pinion, power steering pump, HP and return hoses, front wheel bearings, and outer tie rod ends plugs and wires, fuel filter and a coolant flush, and belts and hoses. Drove for the winter and in the spring I did stage two: wheels, tires, Quick struts, and a cold air intake, u bend, different y pipe and twin magnaflows. Ran great for a year. four months ago my transmission went out. totally stb. I purchased the car with 115151 miles. Trans went out at 158001. I for the most part babied the car. garage kept. synthetic oil every 3k. yada yada yada. Stage 3: New transmission, control arm bushings, had gmpp way bar, put new bushings and end links on, added a trans cooler also, oh and ball joints. Got it put back together, sweet ride. put a 1k miles on her and the CEL started flashing. O2 upstream. O2 Down stream, converter code, and misfire codes. 02 voltages are all over the place. the car runs okay when it is cold. drive it for a mile, goes okay. gets warm, it will kill and wont start if i drive it too long. got her tore apart last night lower intake gaskets were bad, maybe some leakage on the plenum gasket. also vacuum lines were cracked at the t on the s/c. Any thoughs? advise? or otherwise? Sorry about the long read. there are things im missing. Thanks for your time!
    Josh
  2. #2 Re: Lets play "Diagnose Joshs' car" :)
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    change LIM gaskets, replace vacuum lines, done.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #3 Re: Lets play "Diagnose Joshs' car" :)
    Mercer, Pa
    New aluminum style gasket and aluminum elbows.
  4. #4 Re: Lets play "Diagnose Joshs' car" :)
    Sep 2013
    Menomonie
    Will a blown LIM Gasket cause it to not run at all?
  5. #5 Re: Lets play "Diagnose Joshs' car" :)
    Not usually
  6. #6 Re: Lets play "Diagnose Joshs' car" :)
    Max Cook
    Guest
    the getting hot and stalling and not running thing sounds like a crank sensor. Sounds like you should do the LIM and coolant elbows, and perhaps the cat if it has one?
  7. #7 Re: Lets play "Diagnose Joshs' car" :)
    Sep 2013
    Menomonie
    Soooo. Installed new aluminum lower intake manifold gaskets, EGR valve gasket, S/C gasket, valve cover gaskets, throttle body gaskets, s/c oil, oil and filter, coolant, PCV, both O2 sensors, and belts and hoses, and plugs and wires. I went to start it and it runs VERY rough and will die if you take your foot off the gas. It has zero power and sounds terrible. Next order of business is compression check and fuel pressure check. Any other thoughts.....please......
  8. #8 Re: Lets play "Diagnose Joshs' car" :)
    double check the plug wires are on right.
  9. #9 Re: Lets play "Diagnose Joshs' car" :)
    Sep 2013
    Menomonie
    Quadruple checked the wires. plugs are autolite XP104 and wires are Autolite professional series Part# 97000.
  10. #10 Re: Lets play "Diagnose Joshs' car" :)
    maybe one plug got a crack in it from the install? its happened before. its worth pulling the back plugs out to check, those are the ones we tend to crack. 4 and 6 typically.
  11. #11 Re: Lets play "Diagnose Joshs' car" :)
    Sep 2013
    Menomonie
    Okay. I will look into that tonight, when i do a compression test. Also, is there a 'database" or single thread that lists every reading the sensors should be at? Like, MAF readings, MAP readings, TPS, yada yada yada? That would be super sweet!
  12. #12 Re: Lets play "Diagnose Joshs' car" :)
    Sep 2013
    Menomonie
    GOT IT!!!!! Bad MAF Sensor!
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. 1992 Stock Radio/CD player makes "clicking" noise, wont play
    By eight4u in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2013, 12:53 AM
  3. Let's Play "Name That Part"
    By tabor0284 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2012, 01:02 PM
  4. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  5. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
