Thread: Map sensor interchangeability
Results 1 to 17 of 17
  1. #1 Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    The number of mine is 16254539, none of the parts stores around me have that one in stock. Is there any other number that will work that I can see if the have?
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Map sensor interchangeability
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Do a google search gmpartsdirect sells for $36
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  3. #3 Re: Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by 97gtpjoe View Post
    Yeah but that will be over a week to get here from the states to Canada.
  4. #4 Re: Map sensor interchangeability
    Jan 2009
    I'm pretty sure any other map with your year of Prix will work
    Sent from my Nexus 4 using Tapatalk 4
  5. #5 Re: Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    I do happen to have one that looks the same from a while back, i'm sure its a 2 bar as i was looking for one for my truck off ebay and was sent the wrong one. The only number it has is 1006H01 on it. I did hook it up and the car was really rich and the idle surged, so I don't think its the right one. Google didn't turn up anything but one dead end also.
  6. #6 Re: Map sensor interchangeability
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Order the one for 36 dollars from gmpartsdirect and then run without the MAF plugged in until it shows up
    I went NA when a whore left -$300 in my bank account.
  7. #7 Re: Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by indygrandprix View Post
    Yeak ok I'll do that and plug the line from the map.
  8. #8 Re: Map sensor interchangeability
    Feb 2009
    flintnasty MI
    you really dont ever need a map sensor... I would just find something at a junkyard eventually, ANY 2 bar sensor will work.
  9. #9 Re: Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    Hmmm, I wonder why this one I have didn't work? Its the same connector, mabey its a 3 bar? Or possibly a one bar? It looks so close to the same you have to look close to notice any size difference.
  10. #10 Re: Map sensor interchangeability
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    can your further explain this? why do we not need a map sensor?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  11. #11 Re: Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by TEK310 View Post
    Pits called open loop, when one of the map,maf, o2 sensors is wacky, the computer goes into open loop and uses a predetermined afr to run.
  12. #12 Re: Map sensor interchangeability
    Mar 2012
    Dallas
    well yeah, then your car constantly run richer than is needed and runs like crap. unless you tune to run in open loop
  13. #13 Re: Map sensor interchangeability
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    tweeder, try calling Lordco Lordco Parts Ltd. - British Columbia's Source for Auto Parts
    the closest store to you would be in prince George, but it wont take a week just to pass through customs as they are a BC company. Im sure they would be glad to help you out, and im sure they would overnight it if you want.
    ps, I use to live in kitimat as a youngster. I love the drive between terrace and prince Rupert, waterfalls everywhere, just awesome.
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  14. #14 Re: Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    heres a side by side comparison, the pic looks distorted but they practically are the same size.
    Map sensor interchangeability Attached Images
  15. #15 Re: Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Seachicken View Post
    Yeah we have a few parts stores around here just didn't want to spend another $100+\- on another sensor. And I don't want to goto the wreckers as they are rip offs and you never know how the parts will work.
  16. #16 Re: Map sensor interchangeability
    Feb 2009
    flintnasty MI
    Cars run just fine without map sensors. They are used for some load calculations, and even then the base guess alphaN numbers are usually close enough people cant tell. A missing map sensor will not put your car in "open loop".. It never has, never will, and whoever said that just made it up for the fun of it.
  17. #17 Re: Map sensor interchangeability
    Aug 2013
    Kitimat, B.C.
    That would be me, I assumed it was with the maf, coolant temp and o2 for loop decision.
  1. 04 + GP stock radio interchangeability
    By Le Patriote in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2015, 05:23 AM
  2. Radio interchangeability in "02
    By Oatmeal in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2013, 12:16 AM
  3. 3.1L and 3.8L interchangeability?
    By Smokin2000gtp in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-14-2013, 01:38 PM
  4. Transmission interchangeability 99 gtp
    By Scottycamaroz28 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-19-2012, 08:45 PM
  5. 4T65E transmission interchangeability
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-08-2008, 12:56 PM
