Thread: pcm questions?
Results 1 to 9 of 9
  1. #1 Re: pcm questions?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    A pcm or powertrain control module is basically a computer that controls all the setting in your engine and trans. It depends on how the pcm is programmed if it will work in your car. I did give my vin number whenever I got a pcm tuned but I don't know if that is necessary or not.... Whenever I got a mail in tune I told intense all the mods I had on my engine and trans and they adjusted the setting to match my mods. For instance if the pcm you get is set for higher shift points and your motor is stock you will get valve float at high rpm. As far as the vin number thing idk
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  2. #2 Re: pcm questions?
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    Quote Originally Posted by tms8582 View Post
    oh I know that im not a noob, but was just curious about my vin. would not haveing my vin programmed in be a problem?
    99 Silver Gtp here --------------------> http://www.grandprixforums.net/my-99...gtp-80323.html
    slp headers ,straight pipe, intriuge suspension, cai, ported tb, performance roller lifters, and bulit trans. 04+ seats in and le spoiler on
  3. #3 Re: pcm questions?
    Washington Michigan
    I honestly don't know bro.... I know Intense asked for my vin number but that might just be for the appropriate settings for that the model, year etc. In other words a 97 gtp might have slightly different settings and parts than a 2002.
  1. a few questions
    By illy in forum General Tech Discussion
    Last Post: 07-03-2013, 02:38 AM
  2. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. E85 questions
    By ls6velless454 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 08:17 AM
