Thread: Need help fixing EGR code P0401!!!
Results 1 to 7 of 7
  1. #1 Re: Need help fixing EGR code P0401!!!
    lynn, ma
    did you ever figure this out? i just did a lim on my car and 400 miles later i have the same issue. also, possibly related the car will sometimes not start right away, it runs a second, dies and restarts, sometimes i go through this 3 times. once it is running, it's fine, but this is driving me nuts.
  2. #2 Re: Need help fixing EGR code P0401!!!
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    take the egr off and start the car 1port should suck air other 1 will blow out air if either 1 dont work theres your problem, ive seen lower intakes be so clogged with carbon it was hard as a rock and took hrs to clean out especially on 3.1 and 3.4s
    (will be loud when you start it with egr off cuz its gona rev up mite even sumtimes die if it idles the same with egr off u have a clogged port most likely)
  3. #3 Re: Need help fixing EGR code P0401!!!
    Nov 2008
    El Paso, Texas
    i did actually figure this out. What it ended up being was the bypass solenoid on the vacuum line in-line with the fuel pressure regulator and the line that goes to the rear of the engine to the MAP sensor. The valve i guess is supposed to vent some vacuum but it kept it high. I replaced the valve and cleared the codes and it never came back again. What was happening to throw the code is that when the EGR valve opens, the PCM is supposed to see a certain drop in manifold vacuum because of the vacuum leak the open EGR valve caused. When the PCM doesn't see this drop, it set the P0401 code EGR INSUFFICIENT FLOW DETECTED because it assumes that there isn't enough flow since the vacuum detected by the MAP sensor wasn't sufficient.
  4. #4 Re: Need help fixing EGR code P0401!!!
    SE Level Member Stappen720's Avatar
    RockVegas MA
    im having this problem right now, but i dont know what im looking for. I as well checked for vacuum leaks. Cant find ANY! ....I have a turbo setup and i was curious if the boost bypass is suppose to be blocked off from vacuum now or do you still keep it hooked up?
    2000 Grand Prix GTP -- TEP TRANS , TURBOCHARGED. PT67 /1.9 Mod Rockers/CC Valve Springs 105's/Plog/48lb Injectors / Borla Exhaust/ Cartuning PCM / KYB Struts/K&N Intake/Autolite 103/ SD Appearance Package / Tuned by Deekster Derek and Myself ------------------PB - 13.7 at 102.4 MPH <<< soon to be broken!!!
  1. P0305 and P0401 96 3.1L Fixed
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-13-2008, 08:49 PM
  2. Fixing error code P0560
    By dowtrader in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2008, 08:23 AM
  3. Fixing error code P0560
    By dowtrader in forum General Tech Discussion
    Last Post: 07-18-2008, 12:12 AM
  4. Runs bad, won't start...Codes P0401 & P0452
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2008, 06:55 PM
  5. Fixing a deep scratch/chip
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 03-01-2008, 09:04 AM
