Thread: alt bracket
Results 1 to 9 of 9
  1. #1 alt bracket
    Dec 2012
    troll land
    Will an n/a 3.8 alternater bracket work on a s/c 3.8
  2. #2 Re: alt bracket
    it should as long as its from the same year. or group of years, the alternators changed, and so did the bracket over the years.
  3. #3 Re: alt bracket
    GTP Level Member AjL227's Avatar
    IL
    What he said ^
    Horizontal bolt bracket for the 140 amp.
    Vertical bolt bracket for the 125 amp.
    The old horizontal bolt brackets had the water pump elbow cast in.
    The later ones & vertical bolt brackets use 2 elbows.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  4. #4 Re: alt bracket
    Dec 2012
    troll land
    Thanks 03 engine 98 bracket
    Quote Originally Posted by AjL227 View Post
    What he said ^
  5. #5 Re: alt bracket
    99+ bracket is different than 97-98
  6. #6 Re: alt bracket
    Dec 2012
    troll land
    03 shortblock 98 topend (aside from the coil bracket, which is a 2000) a lil more carification
  7. #7 Re: alt bracket
    so a 98 alt is being used?
    the alt you have has to match the bracket. unless you dont have a alt yet, then you can just go find any pair you like.
  8. #8 Re: alt bracket
    Dec 2012
    troll land
    K kool
  9. #9 Re: alt bracket
    Dec 2012
    troll land
    Went ahead and bought the alt bracket off the 01 l67 figured i could get replacements easier
  1. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
  2. where does this bracket go?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2012, 07:02 AM
  3. Name this bracket.... Thanks
    Last Post: 10-21-2009, 07:23 AM
