Thread: URGENT cam question
Results 1 to 18 of 18
  1. #1 URGENT cam question
    Mar 2012
    South Beloit, IL
    I bought a cam here that was supposedly new in box. When I went to take it out of its packaging, it was sticking to it. I cleaned the sticky gunk, but it looks like something stayed from the gunk. I can't get it off. Can someone help me to tell me if this cam is safe to run? Here are pictures:
    https://www.dropbox.com/s/1ybufyua96...2013.25.35.jpg
    https://www.dropbox.com/s/k3csht3wp3...2013.26.33.jpg
    https://www.dropbox.com/s/bbupagr93n...2013.26.35.jpg
    https://www.dropbox.com/s/0ayiyjpget...2013.27.06.jpg
    Also, can you tell if this cam is actually new? If not, I'm pretty sure my cam project is toast, since school starts in a couple of days and I am not going to risk it.
    P.S. sorry about the multiple threads. Just on the heels of this thing and hadn't prepped the cam before..
  2. #2 Re: URGENT cam question
    Pictures aren't working for me
    04 Comp G.
  3. #3 Re: URGENT cam question
    Mar 2012
    South Beloit, IL
    I have had so much trouble trying to upload the pics directly to this website.. I'll give it a try, one sec
  4. #4 Re: URGENT cam question
    antioch ill
    try photobucket
  5. #5 Re: URGENT cam question
    i dont see the typical wear marks of a used cam. it does look like its been left out in open air maybe. steel wool should clean that rust looking spot off the end.
  6. #6 Re: URGENT cam question
    Mar 2012
    South Beloit, IL
  7. #7 Re: URGENT cam question
    Ok I see them now on my computer. That doesn't look like wear marks. Take - little bit of WD and steel wool 0000 and clean it up a bit and then make sure you to lube it properly when you install it.
    04 Comp G.
  8. #8 Re: URGENT cam question
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Looks like slight rust pitting to me. Not ideal but I would run it. The worst looking part on the end is where the cam sprocket bolts to so that does not matter because there is no movement there once the sprocket is bolted up.
  9. #9 Re: URGENT cam question
    If you don't want to run it..send it here and ill run it and will post a video of the awesomeness!
    04 Comp G.
  10. #10 Re: URGENT cam question
    Mar 2012
    South Beloit, IL
    Only if you send me the car afterwards.
    I just tried to do the 0000 steel wool with the WD-40, but it didn't even take a little bit off. Is it safe to run the cam as-is? I just don't want something on the cam to cause problems a couple thousand miles down the road
  11. #11 Re: URGENT cam question
    Quote Originally Posted by Nchristopherson View Post
    It just looks like gunk..not actually wear marks so I would not be concerned if it was my cam.
    04 Comp G.
  12. #12 Re: URGENT cam question
    Daytona, florida
    Same.
  13. #13 Re: URGENT cam question
    Mar 2012
    South Beloit, IL
    Awesome, thanks for the help! I'll post results once I'm finished
  14. #14 Re: URGENT cam question
    I'm lazy to go searching through your post so which can is it?
    04 Comp G.
  15. #15 Re: URGENT cam question
    Mar 2012
    South Beloit, IL
    VS cam
    Sent from my SCH-R530U using Tapatalk 4
  16. #16 Re: URGENT cam question
    Nice
    04 Comp G.
  17. #17 Re: URGENT cam question
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Agreed.
    I'd clean it up as best as possible and install it with no worries.
    Enjoy!
  18. #18 Re: URGENT cam question
    Jun 2013
    Hollywood ,FL
    tuned in to see how install went
  1. URGENT What is this?!
    By PioneerGTP in forum General Tech Discussion
    Last Post: 10-09-2012, 04:49 PM
  2. Need Urgent Help
    By ahl395 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-18-2012, 11:50 PM
  3. Urgent Help Needed
    By tdm571 in forum General Tech Discussion
    Last Post: 04-08-2011, 08:53 AM
  4. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
