Thread: Which pulley should I go with?
Results 1 to 8 of 8
  1. #1 Which pulley should I go with?
    Mar 2012
    South Beloit, IL
    So I've been prepping myself to tackle this camshaft and gasket overhaul for my engine, and I am positive I have everything, except for a smaller supercharger pulley. I don't plan on driving hard core until I get a tune and I just wanted to know which size pulley I should go with based on a VS cam, SD Headers build? I was thinking 3.4, but I'm not sure. Any ideas?
  2. #2 Re: Which pulley should I go with?
    Stock 3.8 until your scanning and tuning
    04 Comp G.
  3. #3 Re: Which pulley should I go with?
    Mar 2012
    South Beloit, IL
    So when I am scanning and tuning, what should I jump to?
  4. #4 Re: Which pulley should I go with?
    Cambridge, Ontario Canada
    Will depend on scans & tuning results... I would think a 3.25 might be in your future but a 3.4 would be a solid start
    2005 E55 - stock
  5. #5 Re: Which pulley should I go with?
    Mar 2012
    South Beloit, IL
    Is there any harm to running the 3.4 when daily driving (not in boost)? Also, is it worth the extra 150 to get wideband support for the hptuners interface
    Sent from my SCH-R530U using Tapatalk 4
  6. #6 Re: Which pulley should I go with?
    3.4 would be my guess and yea DD will be fine as long as the tune is up to par and your not knocking you'll be fine.
    04 Comp G.
  7. #7 Re: Which pulley should I go with?
    Mar 2012
    South Beloit, IL
    3.4 it is! Thanks guys
  8. #8 Re: Which pulley should I go with?
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Same setup as you except a gen v with me, I have a 3.4 on it for a dd you can drive it but stay off boost or take off the belt till you get a to tune it
    If You Cant Hear The Whine You're Too Far Behind...
