I Found a sweet deal on A ZZP LIM for my GTP but its machined for a IC and I don't want to run a intercooler. CanI use it on a NON IC set up
Yes, just fill the channel with RTV, and trim the gasket to match the LIM
Post a picture of what you got. Why run a intercooler manifold without a intercooler? It's not ported.
Porting the LIM doesn't do anything unless its matched to the heads or it's an L36 LIM.
Looks like it just needs a fuel rail stud and a nice cleaning.
as long as the gasket seals.
That's not a ZZP manifold.
No groove.
2 holes are not plugged.
Some one has cut the opening bigger for an intercooler.
Why install this if no intercooler?
that looks like the zzp first version before they did the pcv grove look closer at the coolant ports they are plugged but then again I thought zzp plugged them with something other then red threading plugs
I think he wants to port match the LIM to the heads.
The air flows out the triangle at the other end, it's not going to change it's mind and move the other way. Air, like most things in physics, is lazy.
