Thread: Won't stay running unless I press the gas
Results 1 to 20 of 31
  1. #1 Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    This is a 2002 3800sc in a fiero. I just fired it up for the first time and it won't stay running unless I press the gas. If I taKe the line off the fuel pressure regulator it will start and stay running, I'm not sure if I have my lines propper though. I have gotten rid of the boost bypass. How I have it now is I have one line going from the throttle body to the purge solenoid on the fender and to the line from the fuel tank. Then another seperate line starting at the octopus thing to the fuel pressure regulator. Then another seperate line from the map on firewall to the port under the supercharger. Should I tie in the line from the octopus thingy to the fuel pressure regulator to the map and end at the port under the supercharger?
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Won't stay running unless I press the gas
    The FPR needs to see manifold vacuum.
    So run the line from the nipple of the LIM to the FPR and the MAP.
  3. #3 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    Right on what do I do with the line from the octopus thing?. I already have one blocked off and the large one goes to the brake booster, should o cap that last line off?
  4. #4 Re: Won't stay running unless I press the gas
  5. #5 Re: Won't stay running unless I press the gas
    cap the extra port on top of the super charger, that would be for the climate control in the w body.
    the fat port on top of the sc goes to the brake booster.
  6. #6 Re: Won't stay running unless I press the gas
    Big one is the booster.
    Middle one is the HVAC controls in a "regular" car.
    The 3rd one must go to the BBV.
    So you can only cap the middle one.
    http://i174.photobucket.com/albums/w...GTP/Jam238.jpg
    Like shown in the picture, that 3rd line goes into the BBV.
  7. #7 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    Yeah I got rid of the boost bypass so I'll have to plug that line off then.
  8. #8 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    K I just tied in thefpr to the map and the nipple under the sc and it helps that it will now start but it only runs for a few more seconds and seems to be hunting the dies. Any suggestions now?
  9. #9 Re: Won't stay running unless I press the gas
    You can't get rid of the boost bypass valve if you are supercharged.
    How in the world is it going to bleed off "boost" and run normally.
    We need pictures of this engine, this is way to hard to understand what you've done by guessing.
  10. #10 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    Alot of people get rid of the bypass valve, it's a contraversial topic. It allows instant boost but it's noisier, uses a little more fuel. I did it to clean up the engine as well. I will have to take some pics tomorrow. I do have a few codes:
    p0452
    p0481
    p0243-turbocharger waste gate solenoid, I will delete tat ode as I don't have one.
    p0463
    p0656
  11. #11 Re: Won't stay running unless I press the gas
    Sounds stupid to remove it.
    Its not a turbo, we see boost almost at an instant with it hooked up the correct way.
  12. #12 Re: Won't stay running unless I press the gas
    gardner,mass
    agree ide hook it up and get the thing running correctly first atleast and then if for some only god knows why reason you want to remove it later you can figure it out then
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  13. #13 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    I did a google search and it mentioned the maf. So I unplugged it and the car started and stayed running, so it's something with the maf but what? Not sure how long the engine was sitting before I got it.
  14. #14 Re: Won't stay running unless I press the gas
    gardner,mass
    Try cleaning the maf with maf cleaner, if that doesnt work replace it.
  15. #15 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    I thought in hpt I saw a reading for the maf but mabey not? Ok I'll try cleaning it, hopefully that works.
  16. #16 Re: Won't stay running unless I press the gas
    HPT can read the MAF, but that doesnt mean its not bad.
    MAF failures are very common.
  17. #17 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    I used sensor cleaner but not much of an improvement. It starts and hunts for isle and then dies shortly, any way to test the sensor incase it's something else?
  18. #18 Re: Won't stay running unless I press the gas
    gardner,mass
    Your lettering hurts my eyes. Grab a maf from a jy for cheap. But if the car runs fine with the maf unplugged thats a pretty obv indication its the maf and like ffdp said these mafs are notorious for going bad.
  19. #19 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Ginseng View Post
    Lol sorry about the lettering it came that way from another forum. The thing with our junk yards here is they are crooks there have been times that the part quote is sometimes more than if I were to but it brand new so they're out. It's weird last night after I disconnected the maf it would start up and idle. I cleaned it today and now with it unhooked, it's doing by he same thing within hooked up... It stalls out? . THe only thing I did notice is that with it unhooked it stumbles and misses when pressing the gas.
  20. #20 Re: Won't stay running unless I press the gas
    gardner,mass
    try resetting your pcm by unplugging the battery possibly
  1. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  2. car won't stay running
    By nawarkk in forum General Tech Discussion
    Last Post: 12-18-2012, 11:21 AM
  3. Car won't stay running...
    By 2000GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2010, 06:43 PM
  4. wont stay running
    By DarkCherry in forum General Tech Discussion
    Last Post: 09-24-2010, 11:06 PM
  5. Car will not stay running
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 07:30 AM
