If her pressing on the relay makes it start, then that leads a guy to think that there's a bad connection in that area. Pull the relays one at a time and make sure the contacts aren't corroded. Then try and figure out which one is causing the issue. With a small screwdriver/pick, try and bend it tighter so that the connections are better. I've seen situations where bad connections cause fires.
