Thread: New LIM job and engine keeps choking on acceleration :(
Results 1 to 14 of 14
  1. #1 New LIM job and engine keeps choking on acceleration :(
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    So I did a new LIM job on a 98 GTP with new vacuum lines and for some reason the car seems to choke on hard acceleration. The car seems to idle great and on acceleration it does great also but as soon as you step on the gas it starts to choke and wants to die. It seems that its running to rich. Car has no cat and it does have new fuel filter, plugs , wires, and before the LIM job it was running just fine. I'm stumped and need some help.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  2. #2 Re: New LIM job and engine keeps choking on acceleration :(
    Cambridge, Ontario Canada
    You sure every electrical connector is back in place?
    2005 E55 - stock
  3. #3 Re: New LIM job and engine keeps choking on acceleration :(
    double check the vac lines, and the plugs wires are on right.
  4. #4 Re: New LIM job and engine keeps choking on acceleration :(
    Jan 1970
    Maquoketa, Iowa
    You change plugs before or after the first fire-up?
  5. #5 Re: New LIM job and engine keeps choking on acceleration :(
    Jan 2009
    Quote Originally Posted by FoSHO99 View Post
    Changed plugs before first fire up
    Sent from my Nexus 4 using Tapatalk 4
  6. #6 Re: New LIM job and engine keeps choking on acceleration :(
    Jan 2009
    I'll double check the vac lines , plug wires are correct
  7. #7 Re: New LIM job and engine keeps choking on acceleration :(
    Jan 2009
    Anyone else have some advice?
  8. #8 Re: New LIM job and engine keeps choking on acceleration :(
    Jan 2009
    Ok So I still need help with this problem, the car bogs on boost put it accelerates normally if not on boost any ideas? Has new plugs , wires, and I checked all the vac lines
  9. #9 Re: New LIM job and engine keeps choking on acceleration :(
    I wonder if the MAF sensor could be at fault, or perhaps the map.
  10. #10 Re: New LIM job and engine keeps choking on acceleration :(
    Jan 2009
    I cleaned the MAF sensor , but I still undecided whether thats at fault or not , thinking of replacing. I read the MAP sensor when its bad the engine will run on idle which in this case the car runs fine on idle.
  11. #11 Re: New LIM job and engine keeps choking on acceleration :(
    Pennsylvania
    There are 2 MAP sensors, one is open to atmosphere and one is connected to vacuum... would mixing those up screw up how the motor reacts to boost?
    Sport Edition Kv5 18x8
  12. #12 Re: New LIM job and engine keeps choking on acceleration :(
    Jan 2009
    Quote Originally Posted by FriboRage View Post
    97-03's only have 1 map sensor I believe
  13. #13 Re: New LIM job and engine keeps choking on acceleration :(
    SE Level Member Gpmadness08's Avatar
    Sep 2013
    Peoria IL
    Have u checked fuel pressure to make sure it's within normal range ?
    ~ : Andrea : ~
    2008 GP @>~~\~~~
    Aka Charlotte
  14. #14 Re: New LIM job and engine keeps choking on acceleration :(
    I thought even the 04+ used the MAP as a baro instead of a dedicated baro. I know for sure the 97-03 have one MAP which is used for both.
    Since no one said it, are you sure none of the plugs cracked?
  1. engine sputters under acceleration...
    By GTP2G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2012, 08:29 PM
  2. Really rough idling and choking on acceleration.
    By Flava601 in forum General Tech Discussion
    Last Post: 02-13-2012, 12:52 PM
  3. Engine stuttering on hard acceleration
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2011, 07:09 PM
  4. engine idle rough, acceleration bad
    By ksredryder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2010, 08:30 AM
  5. Choking under boost?
    By boysatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 11:07 AM
