Thread: engine sputters under acceleration...
Results 1 to 10 of 10
  1. #1 engine sputters under acceleration...
    SE Level Member GTP2G's Avatar
    louisville ky
    so i just replaced the lim gaskets, s/c gasket and all that other good stuff. put everything back together and the car starts and idles perfectly. but when i accelerate or give it some throttle the engine sputters real bad. almost like a missfire. i changed the plugs and still did not solve the problem. its not throwing any codes either. any help or insight would be great. thanks.
  2. #2 Re: engine sputters under acceleration...
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Try unplugging your MAF and take it for a short drive and see if it runs better.
  3. #3 Re: engine sputters under acceleration...
    louisville ky
    just tried that (unplugging the MAF) no dice. car wouldnt even accelerate with it unplugged. wanted to die
  4. #4 Re: engine sputters under acceleration...
    did you unplug it while the car was on or off? if you unpluged it while it was running , unplug it while its off, then start it.
  5. #5 Re: engine sputters under acceleration...
    louisville ky
    unplugged it while it was off, then started it.
  6. #6 Re: engine sputters under acceleration...
    hate to even ask but your sure the wires are on the right plugs and coils?
    [IMG][/IMG]
  7. #7 Re: engine sputters under acceleration...
    louisville ky
    lol yea they are all correct. that was the first thing i checked. but even if they were wrong. would the car still idle perfectly. because it idles fine only acts up under acceleration or if i give it some throttle
  8. #8 Re: engine sputters under acceleration...
    a few of the cylinders fire so close to each other it could misfire one way or the other, just a thought, cant hurt to cover all bases.
    could be a vac leak, try spraying starting fluid or carb and choke cleaner around the engine and listen for the rpms to jump.
    have you been driving it at all or just trying to get the problem solved? as driving it around for a few short trips may get the cel to pop on, then you'll have a better idea where to look.
    did the cel come on when you pulled the maf plug? and then go back out after you reconnected it?
  9. #9 Re: engine sputters under acceleration...
    louisville ky
    got it figured out, i changed the wires out with some new ones and the problem is gone. must have had a bad wire or some thing. anyways. seems to be doing good now. thanks for your help though scotty
  10. #10 Re: engine sputters under acceleration...
    no problem glad to see you got it all straightened out.
  1. Engine quits during spirited acceleration
    By Jedi 41 in forum 5.3L V8 (LS4)
    Last Post: 01-13-2012, 01:42 PM
  2. Engine stuttering on hard acceleration
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2011, 07:09 PM
  3. misfires/boggs during hard acceleration when engine is warm
    By baker01gt in forum General Tech Discussion
    Last Post: 09-23-2011, 06:43 AM
  4. engine idle rough, acceleration bad
    By ksredryder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2010, 08:30 AM
  5. 1998 Gd Prix sputters and stalls when engine warm
    By jmickevi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 02:05 AM
