Thread: KR at WOT after intake
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 KR at WOT after intake
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Just as the title of the thread says - I'm running a '99 GTP with 210k which (had) zero degrees of KR at WOT until I built and installed an open cone intake. After that, I got 2-4 degrees at WOT above ~4k, which was not solved by installing a downpipe. Adding a bottle of 104+ octane booster didn't do anything to reduce KR, either.
    No DTC's except for P0140 (rear O2 sensor that I pulled when installing the downpipe), and I just put in new spark plugs and wires.
    Video: Accelerating up the onramp - YouTube
    The gizmo up front is a Linear Logic scangauge which is showing (on the right side) AFR and KR.
    I guess I should be asking if this is false knock? I'm really itching to do a pulley drop.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  2. #2 Re: KR at WOT after intake
    the octane booster didn't add any octane so that was a waste of money.
    was the weather different on the days where you noticed more/less knock?
  3. #3 Re: KR at WOT after intake
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    That 104 booster is garbage. As is most octane booster. Your not at 104 anything. I'd be surprised if you added 1 point to your system. ( 93 pump with booster would be 94 octane ). If you have access to race gas, add a few ( 3 gallons) , then fill up with pump ( 91-93 ) more than likely it will go away.
    Also how hot was it ( ambient temp ) when you run an open cone the intake temps tend to shoot up real quick. Which would lead to kr as well.
    Even on a 99 I would suggest headers before any pulley drop. And even after headers I'd only drop to a 3.5 max.
  4. #4 Re: KR at WOT after intake
    Jun 2013
    Beavercreek, OH
    That's the goal I was hoping to achieve with the octane booster - add a point or two and see if it reduced the KR, so I could at least diagnose the problem. I have access to race gas and can give it a shot, but at $6 a gallon it isn't a permanent solution. I'll have to see if it changes anything, though, and report back.
    Ambient temps were in the low 60's. Ambient temp has little or no relation to the amount of KR I'm getting - I've seen it on cool nights and blazing hot days in roughly the same amount - always 2-4*.
  5. #5 Re: KR at WOT after intake
    well, something has changed. what kind of HAI did you go to? do you still have a MAF screen?
  6. #6 Re: KR at WOT after intake
    Jun 2013
    Beavercreek, OH
    Bio248--
    Changed the stock box to this guy:
    The MAF screen is still there. The MAF sensor was replaced about a month ago (about 2 weeks before I put the intake on).
    A thought: Could the intake cause the system to run too lean? (I'm already seeing AFR at 11 at WOT though?)
  7. #7 Re: KR at WOT after intake
    Nov 2012
    MN
    The intake/ air setup does change the aircoming in but 4* seems a bit much. The tune would dial in the Afr and maf, but it still deems a bit much. Pit a 3.6 on, or until then put 3 gallons of race gas in. At the very least you will find out if its false kr or not, and more than likely will really like the results. My setup is pretty stock. Overkill PCM, no cat no res, 605s 180* stat and a shift kit. Even on stock pulley I see kr. I add some 110 to it and its all gone plus its never boggy, throttle response is great and it really does seem to make the car run better.
  8. #8 Re: KR at WOT after intake
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by comatoast View Post
    comatoast--
    Currently on the stock pulley and stock tune. Are you saying that a canned tune (dhp, Intense, etc.) would dial in the MAF/AFR better and reduce/eliminate the KR?
  9. #9 Re: KR at WOT after intake
    Still have a U-bend?
    Bringing in more air.
    Still can't get rid of it.
    Go have an exhaust shop hack that out...bet that would solve the KR...or a downpipe in general...3"...
  10. #10 Re: KR at WOT after intake
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by blueguy View Post
    blueguy--
    That's why I'm confounded-- I installed a 3'' downpipe and it made no difference in KR.
  11. #11 Re: KR at WOT after intake
    I don't read details, hah. Flip the dog bone mounts?
    Are the lower mounts shot causing contact between the downpipe and sway bar? Also, just toss the front of the box out...the PCM will sit on the fender and not move...did that on both my cars. If you're worried about that then you can get a Blazer/S10 PCM tray...they bolt right in.
  12. #12 Re: KR at WOT after intake
    Nov 2012
    MN
    Quote Originally Posted by hensleya1 View Post
    comatoast--
    My intense tune sucked. My overkill PCM is much better and is probably the best IMO.. In the same scenario, same gas, same weather same temps my overkill PCM cut my kr in half. I would usually see 5-6* kr with stock PCM now I barely see more than 2* ever. If I do see more its usually crap 91 gas that causes it, as we only have one station here with 93.
    So to answer your question. Yes a canned tune PCM will help performance and reduce kr, but will not kill it all. I don't think will ( overkill ) touches the maf tables unless you have him tune for a cam, I/c, or other major mod. Fuel tables are left untouched as well I believe.
  13. #13 Re: KR at WOT after intake
    04-07 cars aren't a fair comparison because the PCM commands overly aggressive timing.
    If better fuel doesn't help the knock, then mods won't. Likely there is something else wrong that is causing the PCM to believe there is knock. See Blue's post for more.
  14. #14 Re: KR at WOT after intake
    Nov 2012
    MN
    Regardless. Add 3-4 gallons of 105+ race gas. You should not see one tenth of a degree of kr.
  15. #15 Re: KR at WOT after intake
    Not practical though.
    Band-aiding isn't the best option either.
  16. #16 Re: KR at WOT after intake
    Nov 2012
    Madison
    Isn't the front of the old air box more of a heat trap after the cone install? I would think it would stop a good chunk of incoming air.
  17. #17 Re: KR at WOT after intake
    I live here. TLSheff's Avatar
    I wish I had access to race gas. Closest track is about 60-75 miles away. Unless I can mix in jet fuel? We have a airport with fueling station for them...
    would that work? haha
    I have a similar issue on mine, stock pulley, intake, SD Headers, DHP1.0 but still seeing 4-5* KR. Need to drive around and see about a 93 station, most I've seen local are only running 91 and none of them work better than the other for getting rid of the KR.
  18. #18 Re: KR at WOT after intake
    The Boss Iceman6669's Avatar
    Jun 2011
    I am going to agree with Blue and Matt... I think there is prolly another issue somewhere that is causeing KR. I run a very similar intake but without the bend... I even had my tuner check the MAF frequency to make sure my MAF numbers were not skewed and they were fine. I dare say it has little to nothing to do with the intake.. But like said about remove all the stock airbox for better/cooler air flowing to the filter..
    2011 F-150 Yote powered
  19. #19 Re: KR at WOT after intake
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by Iceman6669 View Post
    Iceman66969--
    I tried searching for this but came up with nothing - exactly how is the other half of the stock air box removed? I couldn't figure it out for the life of me (and if I can pull it off, I'll add a larger filter at some point).
  20. #20 Re: KR at WOT after intake
    Max Cook
    Guest
    take the belt off and see if it goes away?
  1. Short Ram Intake, Fender Well Intake, Etc.?
    By Pokealong1227 in forum General Tech Discussion
    Last Post: 05-31-2013, 12:26 PM
  2. Replies: 81
    Last Post: 02-14-2013, 02:57 AM
  3. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
