Thread: Keeps killing batteries
Results 1 to 9 of 9
  1. #1 Keeps killing batteries
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    I have a 2001 gtp. It keeps killing my batteries randomly. One battery died. And so I put a new on in killed that one I'm a week. Recharged it. Killed it ago a couple days later. Charging system is good. I had my car running and pulled the positive lead on the battery and car ran fine. So I know the alternator isn't bad
    2001 sliver gtp her name is Reagan
  2. #2 Re: Keeps killing batteries
    test the power draw off the battery when its off, and then again when the battery is unhooked, seems like something is drawing power when the car is off.
    any chance you installed a aftermarket radio or anything before this started to happen?
  3. #3 Re: Keeps killing batteries
    Oct 2012
    Fort Wayne, Indiana
    Nope. I just got the car not to long ago. My radio is stock but does something weird. The place it shows time and radio station well it goes haywire sometimes
  4. #4 Re: Keeps killing batteries
    if the battery is dyeing over night. pull the radio fuse, see if that helps. could be drawing power when the car is off.
  5. #5 Re: Keeps killing batteries
    Oct 2012
    Fort Wayne, Indiana
    It only randomly kills it. I could turn my car off and 2 minutes later it'll die. Or it will last a couple days
  6. #6 Re: Keeps killing batteries
    Oct 2012
    Fort Wayne, Indiana
    But I'll try that and see if it works. I have been just pulling my negative battery cable as soon as I shut my car off
  7. #7 Re: Keeps killing batteries
    Dec 2012
    Where 4T65E's were born
    If keeping the battery disconnected while you're not using your car is preventing it from dying, a parasitic load is likely the cause. You will need to monitor amperage while it's shut off to be sure. I'm not sure how it could die in 2 minutes, actually that's quite impossible...Must be another issue when that happens.
    Sold.
  8. #8 Re: Keeps killing batteries
    Oct 2012
    Fort Wayne, Indiana
    Well that's how it's happened a couple times. Once like that. Then once while putting 25 bucks of gas in
  9. #9 Re: Keeps killing batteries
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Dying that fast sounds exactly like what happened to my buddies car. His alternator was bad but if yours is good then it must be something else. As far as the radio going haywire, mine used to do that too. I just replaced it with an aftermarket one. There could be a possibility that the radio is drawing power through a short maybe.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  1. rc batteries
    By Matt Palm in forum Buy/Sell Other/Misc
    Last Post: 06-20-2013, 12:47 PM
  2. Kirkland batteries
    By Pure2sin in forum Audio, Security & Visual Electronics
    Last Post: 01-13-2012, 06:07 AM
  3. Are optima batteries really worth it?
    By jmoore4294 in forum General Tech Discussion
    Last Post: 04-13-2011, 07:18 AM
  4. Dual batteries
    By masterhacker in forum General Tech Discussion
    Last Post: 05-30-2010, 03:05 AM
  5. 4 bad batteries in 4 months, what gives?
    By dhall9 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2010, 06:35 PM
