Thread: Tips before starting cam build
Results 1 to 9 of 9
  1. #1 Tips before starting cam build
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Hey, I've fairly well got far in my build and stuff, engine got back in car yesterday evening.
    Car is a '04 Comp-G w/ 65k
    What I've put in is ; New head gaskets, got the heads magnafluxed + milled + ls6 springs + modded retainers and viton valve seals, ls7 lifters and a XP cam.
    Now what my question is ; Is my order / "break-in" / oil change order fine.
    So on the startup tonight what I planned to do is ;
    1; Fill it up with new coolant & oil,
    2; Do the security relearn for the Overkill PCM
    3; With the fuel pump relay removed; prime the engine oil pressure for a few cycles, waiting a few secs in between.
    4; Re-install fuel pump relay and attemp to crank, see if everything sounds fine or not,
    5; If everything sounds okay, let it idle up to operating range, bleed coolant,
    6; One coolant is bled, change the oil a second time,
    7; Crank her up again, go in for a 100-200 drive
    8; If no rod knock, change oil for a third time,
    9; Be happy that my cammed build works, have a beer, or two, or three.
    Anything I missed?
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  2. #2 Re: Tips before starting cam build
    I changed my oil after 1000 miles then 3000 after that.
  3. #3 Re: Tips before starting cam build
    Québec
    Well I started it up, lifters took about 2-3 mins to pump up, then it sounded pretty darned good, had no issue starting at all and so far made its way home, about 20km done.
    Left it idle for about 15-20 mins to bleed coolant and see if everything is fine, changed oil, now my mech suggested that I keep this oil for a ride back and forth to work, about 300km, then change oil(That would be my third one)
    Now I'm pretty slow on the throttle, keeping it under 2-3k as much as possible.
  4. #4 Re: Tips before starting cam build
    No need to be easy on the gas. Go beat in it. You won't hurt anything
  5. #5 Re: Tips before starting cam build
    Québec
    Mmhm, just for a peace of mind, I like to keep it slow / out of boost.
    So far I've got 50km on it and about 1h30 of running since the cam swap, 2 oil changes, 50km on the second oil change.
    Everyone suggests me to drive at least 500km with it, which I will do, so if I change my oil next thursday evening, I'll have roughly around 500km.
    So far everything seems to run fine, anything I should worry about still? May I release some of the stress and enjoy the lope?
  6. #6 Re: Tips before starting cam build
    Banned
    Jan 2013
    Colorado
    Are you really supposed to do all this coolant draining procedures and changing the oil soon after?
  7. #7 Re: Tips before starting cam build
    Québec
    Well coolant... All I did was drain it before cracking the engine open, then emptied the whole remaining in block with a vacuum/straw.
    Main thing about oil is to make sure there's no trace of coolant left, thus after the job, drain it, put fresh oil/filter, let it run till you have time to bleed coolant of all the air, then shut down, drain again, and drive it for 500 miles or so, then change again. This is what I've been recommended, and after blowing an engine in the past after a LIM job, I take no chances anymore.
    Also another question to pals with XP cams, what is your vacuum like? Idling mine seems to be around 15-16 in/hg. If I recall it's lower due to the cam & drive-by-wire TB.
  8. #8 Re: Tips before starting cam build
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Honestly when I did my cam swap I didn't do any of that or motor swaps just started them up at the first crank. Never had a issue at all. Only thing I did is the oil and coolant of course but besides that ran it slow till I got a tune 2 days later.
    If You Cant Hear The Whine You're Too Far Behind...
  9. #9 Re: Tips before starting cam build
    Feb 2009
    flintnasty MI
    Following the plan you have is good. Its worth the $15 to throw oil in a few times to make sure you get all the water out of the motor... It likes to hide in the cam valley as well as other places.
  1. Starting to build up the intrigue, finally
    By intrigue98 in forum Members Rides
    Last Post: 04-04-2017, 09:10 AM
  2. 00' Grand Prix GTP (Build starting)
    By Stinkygrub in forum Members Rides
    Last Post: 04-09-2012, 10:48 AM
  3. trouble starting after topswap/build
    By MrClean in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2011, 11:08 PM
  4. Starting the new build soon:)
    By bballa0740 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 09:34 PM
  5. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
