Thread: Motor swap
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Motor swap
    One thing I've built for a few swaps etc...is a patch cable. Meaning if you take the interior harness piece for the engine harness you are using and the engine harness piece for the interior harness you are using and you map them out, then solder and heat shrink the wires, you make your self a piece that connects and keeps you from hacking the engine harness or interior harness. It also allows you to easily fix any wiring issues you might make.
  2. #22 Re: Motor swap
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    It dosent seem like there would be alot of wiring work to do,I've been comparing the wires on my gtp and se and alot have the same connectors
  3. #23 Re: Motor swap
    Florida
    I just labeled the wires I moved and taped them with the label and moved the pins. No real cutting. Just one slice.
  1. Help with motor swap
    By Jroscoe in forum General Grand Prix Discussion
    Last Post: 08-07-2013, 08:10 AM
  2. Motor swap
    By Pontiac Man in forum General Grand Prix Discussion
    Last Post: 02-26-2012, 10:27 PM
  3. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  4. Motor Swap
    By Rolling89GPSE in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-26-2010, 05:09 PM
  5. motor swap
    By ericevenski in forum Off Topic Discussion
    Last Post: 02-20-2010, 05:16 PM
