Thread: Motor swap
Results 1 to 20 of 23
  1. #1 Motor swap
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Yes I understand its been discussed literally a 100 times probably,I want a 100% answer,I'm getting a Montana and I want to put the l67 in it,if the 3.8 sc bolts right in the grand prixs it should the Montana right?,I know I need the PCM and harness,what else do I need,can I keep the fuel pump that was with the 3.4 or do I need the 2 speed if so how will it wire up,I want to do it,I'd like a 2000 or up since it has that updated speedo,can I get a exact answer what I need and what to do,I know it works it's been done,thanks
  2. #2 Re: Motor swap
    Subframe is a direct swap out. A regal is closer in the wiring so less splicing is needed.
  3. #3 Re: Motor swap
    Jul 2010
    Does a subframe just bolt in or does it got to be welded,how much of the harness do I need,so a gtp subframe will go right into the Montana?
  4. #4 Re: Motor swap
    Jul 2010
    How come the regals wiring harness is different than the grand prixs?,when I do splice will it be pretty much colors to colors? or do I need a diagram?
  5. #5 Re: Motor swap
    I've never done it but from my research that's what I've found.
  6. #6 Re: Motor swap
    Jul 2010
    Ok thanks
  7. #7 Re: Motor swap
    Subframe doesn't need welded just bolts right up
  8. #8 Re: Motor swap
    Jul 2010
    Ok that's good,probably would have to take the front end off the mini van to get the motor in,I'm def going to do it,probably start this winter,so basically all the cars with the 3.8 sc subframe will work?
  9. #9 Re: Motor swap
    Jul 2010
    On the 96 Grand Prix they started obd 2,would it be the same deal with it,swap subframes,96 would be easier to wire up probably not to sure lol since it's obd2
  10. #10 Re: Motor swap
    96's are what's called obd 1.5 iirc. They have the obd2 port but the wiring is just like obd1
  11. #11 Re: Motor swap
    Jul 2010
    Oh ok didn't know that
  12. #12 Re: Motor swap
    I'm thinking there were some trans sports with the 3800 in them already.
  13. #13 Re: Motor swap
    Jul 2010
  14. #14 Re: Motor swap
    Yeah that's Charlie's he's a member on here
  15. #15 Re: Motor swap
    Jul 2010
    I need to talk to him lol,if you know him and he gets on tell him to pm please
  16. #16 Re: Motor swap
    He hasn't been on in a long time
  17. #17 Re: Motor swap
    Florida
    Yeah I actually got steel braided fuel lines out of a 3800 powered lumina van. You deff don't want to cut the harness and try to match color to color. Many wire share the same color with just minor dots to differ and can share the same ground color. Deff done want to cross the wires. You will need to get the c100 pin outs and PCM pin outs for the donor car and the car it's going into and match wire for wire. On my swap from the 96 DOHC to the 98 L36 there was one ground wire I had to add and one or two I removed. And these were both z34montes. So they were dry close. The pump should be ok. If your installing the l36 the it is set for a single speed pump anyway. At least on my z for 98 they are single speed. If not it can be changed in tiny tuner. Other things I had to address were: ac lines but mine worked, power steering lines, throttle cables were diff, fuel lines. I think that was about it. If you are going to mod the car you might as well do what you can to get headers installed if they can fit.
  18. #18 Re: Motor swap
    Jul 2010
    What's the c100 pins?
  19. #19 Re: Motor swap
    Florida
    The c100 is the connector at the firewall
  20. #20 Re: Motor swap
    Jul 2010
    Oh ok thanks,it dosent sound to bad,just to verify when you say out your talking about the male ends or female?how would I wire up a 2 speed pump like its suppose to in the relay/fuse box under the hood?
  1. Help with motor swap
    By Jroscoe in forum General Grand Prix Discussion
    Last Post: 08-07-2013, 08:10 AM
  2. Motor swap
    By Pontiac Man in forum General Grand Prix Discussion
    Last Post: 02-26-2012, 10:27 PM
  3. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  4. Motor Swap
    By Rolling89GPSE in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-26-2010, 05:09 PM
  5. motor swap
    By ericevenski in forum Off Topic Discussion
    Last Post: 02-20-2010, 05:16 PM
