You do not want manifold vacuum to that pcv nipple. That is for the fresh air intake part of pcv. You can either remove that cap on the northstar and put in a fitting like bill said above or run the hose to a fitting anywhere between the MAF and throttle body. As far as the evap you can tap that hole and plug it or make a block off plate.
