Thread: Supercharger makes spitting sound
Results 1 to 20 of 22
  1. #1 Supercharger makes spitting sound
    Aug 2013
    Indiana
    Hey, I have a 1998 Grand Prix, and under medium to heavy acceleration the supercharger kicks on and makes a loud spitting sound and the check engine engine light flashes, it's throwing the "P1646D, Boost control solenoid control circuit" code. I honestly have no idea what could be wrong. Never dealt with supercharges before, any help is appreciated
  2. #2 Re: Supercharger makes spitting sound
    Flashing check engine light means possible catalyst damage.
    Which useally leads to misfires.
    If it was me I would replace all the spark plugs and replace the boost control solenoid.
  3. #3 Re: Supercharger makes spitting sound
    Aug 2013
    Indiana
    I just put new spark plugs in about a month ago, so ill probably pickup a boost control solenoid and see if that fixes the problem
  4. #4 Re: Supercharger makes spitting sound
    Which brand?
    Also double check that none of the wires came off the plugs.
  5. #5 Re: Supercharger makes spitting sound
    Aug 2013
    Indiana
    AcDelco rapid fire plugs, ill have to check the wires too
  6. #6 Re: Supercharger makes spitting sound
    Aug 2013
    Indiana
    Which brand?
    I checked on auto zones website and they don't have a Boost Control Solenoid, but they have a Supercharger Bypass Solenoid. Are they the same thing?
  7. #7 Re: Supercharger makes spitting sound
    I believe so.
  8. #8 Re: Supercharger makes spitting sound
    Quote Originally Posted by Thomasp1717 View Post
    these plugs? Ac-Delco-Rapidfire | AC Delco Plat/Spark Plug (14) | AutoZone.com
    if so theres your problem, they are plats.
    run copper core or iridium plugs.
  9. #9 Re: Supercharger makes spitting sound
    Aug 2013
    Indiana
    Platinum plugs are that bad? I thought they were recommended
  10. #10 Re: Supercharger makes spitting sound
    For some GM cars, the 3800 called for a Iridium style plugs from the factory.
    The waste spark ignition system doesnt like platinum plugs.
  11. #11 Re: Supercharger makes spitting sound
    Feb 2013
    37.295091, -121.930053
    better question were does it say they are good on this forum? copper or Iridium work the best
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  12. #12 Re: Supercharger makes spitting sound
    nope, they suck in our engine. iridium i or copper core is the way to go.
    the plats cause misfires, like your getting with the sputtering. its a misfire or 6.......
  13. #13 Re: Supercharger makes spitting sound
    Aug 2013
    Indiana
    Well I guess I'll try new plugs first then
  14. #14 Re: Supercharger makes spitting sound
    the iridium's will last a good 70,000 miles or more. the copper plugs 12 to 15,000 tops, the copper are cheap at 2 bucks a plug. people with a good amount of mods run the copper for the most part. all stock stick to the iridium's.
  15. #15 Re: Supercharger makes spitting sound
    Feb 2013
    or if you just got a replacement engine copper are best just in case the engine you got has mods and you didnt know. thats what i did and my car loves them
  16. #16 Re: Supercharger makes spitting sound
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    I run NGK iridium's in mine with the acdelco plugs.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  17. #17 Re: Supercharger makes spitting sound
    Quote Originally Posted by 1996pontiac View Post
    you use 2 different plug types at one time? NGk and acdelco are not the same company. pick one or the other.....
    myself i use only ac plugs.
  18. #18 Re: Supercharger makes spitting sound
    Im guessing he meant wires.
  19. #19 Re: Supercharger makes spitting sound
    Feb 2013
    personally i would love to see this he does say acdelco plugs
  20. #20 Re: Supercharger makes spitting sound
    I live here. TLSheff's Avatar
    Techinically ACDelco plugs are NGK Iridiums...
    just sayin.
  1. Supercharger sound..
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2013, 01:26 AM
  2. can you make supercharger have turbo blowoff sound?
    By DrSnazzy in forum General Tech Discussion
    Last Post: 06-25-2012, 12:11 AM
  3. spitting and sputtering
    By humesrichard in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-12-2012, 05:12 AM
  4. 96 GPSE 3100 spitting,sputtering,and backfiring
    By 96gpse in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-21-2009, 09:46 PM
  5. supercharger deep sound
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2009, 05:00 PM
