Thread: whats wrong! wierd shuttering after 4k
Results 1 to 20 of 31
  1. #1 whats wrong! wierd shuttering after 4k
    Feb 2013
    Duluth, mn
    I just bought a 04 gtp comp g. after 4k rpm the car seems to be hesitating really bad. im going to try to upload a video to help you guys out
  2. #2 Re: whats wrong! wierd shuttering after 4k
    tune up time? how many miles does it have?
  3. #3 Re: whats wrong! wierd shuttering after 4k
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    smell like rotten eggs? clogged cat?
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  4. #4 whats wrong! wierd shuttering after 4k
    Feb 2013
    Duluth, mn
  5. #5 Re: whats wrong! wierd shuttering after 4k
  6. #6 Re: whats wrong! wierd shuttering after 4k
    Looks like it needs a tuneup to me.
  7. #7 Re: whats wrong! wierd shuttering after 4k
    Car sounds modded.
  8. #8 Re: whats wrong! wierd shuttering after 4k
    Feb 2013
    Duluth, mn
    It's bone stock other than a could air filter. And no rotting egg smell or anything like that.
  9. #9 Re: whats wrong! wierd shuttering after 4k
    I'd start with plugs and wires.
  10. #10 Re: whats wrong! wierd shuttering after 4k
    SE Level Member crysalis's Avatar
    Mentor, OH
    Mine did this too. Swapped plugs and found a vacuum leak. Do a tuneup and if not, smoke test!
    Here was my video.
    https://www.youtube.com/watch?v=y11z3Uj9O5c
    2006 GP GT S/C | CAI | Overkill PCM | PLOG | 3" Catted DP | ZZP Strut Brace -- SOLD the car in treason for a Hemi Charger >:]
  11. #11 Re: whats wrong! wierd shuttering after 4k
    Feb 2013
    Duluth, mn
    Crysalis... That's exactly what mine is doing. I just picked up some auto lite 605s along with new wires going to install them as soon as my car cools off... I will be on the look out for a vacuum leak. What is a smoke test?
  12. #12 Re: whats wrong! wierd shuttering after 4k
    smoke test is when they pump smoke in the vac lines, then watch for the leak via smoke leaking out.
    you can also let the car idle, then spray carb cleaner at the vac lines, if the idle jumps up you found a leak. move the lines a bit when spraying them, this helps find cracks that dont leak much due to the weight on them holding them tight.
    if the vac leak is large enough the idle will be jumping up and down, hunting if you will, and sound like you just installed a nice loopy cam lol
    so if your idle is nice and smooth chances are the vac lines are ok. most of the time.
    i do think you'll be right as rain after the plug change tho.
  13. #13 Re: whats wrong! wierd shuttering after 4k
    Feb 2013
    Duluth, mn
    i just pulled out the front side plugs and found them to be acdelco 41-101 they look to be a platinum... let me know for sure...but there brand new
  14. #14 Re: whats wrong! wierd shuttering after 4k
    gardner,mass
    those are iridiums
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  15. #15 Re: whats wrong! wierd shuttering after 4k
    Feb 2013
    Duluth, mn
    ok after a little googleing i found that its not a platinum and its the ac delco stock brand...so my next question is.. whats better for my car the acdelco or the al 605s car is pretty much stock other than a 180t stat witch im putting in now, resonator delete (old one rusted out) and the cold air.
  16. #16 Re: whats wrong! wierd shuttering after 4k
    ACDelco 41-101 Professional Iridium Spark Plug, Pack of 1 : Amazon.com : Automotive that comes back to iridium plugs.
    you may have a bad icm if they are all iridium plugs int he engine, pull the rest, check them out for damage and that part #, if they areall good put them back in.
    did you gap the new plugs when you put them in? or just went with what they are from the box?
  17. #17 Re: whats wrong! wierd shuttering after 4k
    a cracked plug will also make the car misfire like that, the rear # 6 and #4 plugs (the rear middle and right plugs) are famous for breaking during the install. i use a plug socket, its got a foam insert inside the socket to protect the plug from cracking.
    so check for cracks in the porcelain part of the plugs.
  18. #18 Re: whats wrong! wierd shuttering after 4k
    Feb 2013
    Duluth, mn
    yeah im using a plug socket. and what do you recommend the gap to be? i havnt put any plugs back in yet cuz i wanted to find out what ones to use first.
  19. #19 Re: whats wrong! wierd shuttering after 4k
    gardner,mass
    just use al 606 or 605 and change them every 10k miles
    gap at .055
  20. #20 Re: whats wrong! wierd shuttering after 4k
    stock is .60 but .58 its ok, its where i am. some go smaller but your all stock so keep it close to .60
  1. not sure whats wrong...
    By tc8706 in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 09:07 AM
  2. someone please tell me whats wrong
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2011, 03:39 PM
  3. whats wrong with my car now?!
    By mezzoni in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2010, 12:41 AM
  4. Whats wrong with my car?
    By basshead42 in forum General Tech Discussion
    Last Post: 07-01-2009, 04:25 PM
  5. whats wrong with the se?
    By blazedgp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2008, 09:20 AM
