Bump!
To my knowledge none of the 04+ fuel pumps had a venturi bucket from the factory but the Delphi and Airtex replacement pumps/buckets do have them. Look close you can see the venturi hose. this is the Delphi pump
Basically you could do 2 things. 1- buy a whole unit like in the pic and drop pump of your choice in it. 2- grab a 97-00 bucket with venturi and retrofit it to your tophat. This is what I plan on doing. the buckets are nearly identical and snap right into eachother. I already have the racetronix pump/rewire in my stock sending unit but it runs dry below 1/2 tank.
But Tengis is right, the returnless system on the 04+ runs at a constant 60psi and has no boost reference like the older systems. The system relies on and requires more from the injectors than the 97-03. So IDEALLY if you want to increase fuel pressure with boost, you would have to plumb a return line.
So it's not a matter of what pump will work with 04+, they pretty much all will. it's more a matter of if your setup requires that extra pressure from the pump to keep the fuel supply
hope that helps
