Thread: O-ring Placement
Results 1 to 4 of 4
  1. #1 O-ring Placement
    Jul 2013
    Oakland, Ca.
    Guys, I'm getting ready to wrap up with this head gasket job on a '97 GTP, but have a question. In the head gasket set they included some o-rings that I'm not sure where they all go. I have two yellos, two orange, and three black o-rings. I'm pretty sure that the two yellows go on the intake/supercharger, but am not sure of the rest. Can anybody help please?
    This is the kit:
    Fel-Pro HS9089PT1 - Head Gasket Set | O'Reilly Auto Parts
  2. #2 Re: O-ring Placement
    The oranges would be for the coolant elbow, however you should automatically replace the elbows. the blacks.. pcv is one and I know there's likely a thermostat gasket.. that leaves probably 1.. usually there's a spare of something large that we don't use, like an old distributor gasket
  3. #3 Re: O-ring Placement
    Jul 2013
    Oakland, Ca.
    Thank you for the quick response. The elbows are being replaced with metal Dorman pieces for sure. For the supercharger/intake there are only those two yellows ones that go in between right?
  4. #4 Re: O-ring Placement
    yes
  1. Amp Placement
    By MattF in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2013, 08:29 PM
  2. Sub Placement Help?
    By ShadowSwept in forum Audio, Security & Visual Electronics
    Last Post: 06-30-2012, 09:34 PM
  3. CV axle: snap ring and abs ring
    By TheBeastGTP in forum General Tech Discussion
    Last Post: 09-13-2010, 03:47 PM
  4. PCM placement
    By Justin33 in forum General Tech Discussion
    Last Post: 02-03-2010, 12:28 AM
  5. sub placement
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 11-15-2008, 06:20 PM
