Yeah. Whatever prevents the clutch from actuating when the pressure is not high enough. You'll hear it if you fill your system up with r134a and if your AC is "running". It will suddenly click on and you'll hear your engine increase it's load, you don't have to watch it. Also, your fans should start spinning faster to move more air across the radiator and AC condenser.
