Thread: getting kr on stock pulley
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    So I have a 05 gtp I have intake SD headers 180 tstat al 606p spark plugs and just bought torque pro app now at wot I see no kr until my car shifts to second or third I've seen 2.5 4 and 5 is this normal on a stock pulley I have all the supporting mods I want to drop to a 3.6 so that I cam have phoenix in car tune my gtp am I ready for a 3.6 or am I knocking too much how can I get kr down more ?
  2. #2 Re: getting kr on stock pulley
    Why would you drop to a smaller pulley if you're seeing KR on a stock one?
    Explain that.
  3. #3 Re: getting kr on stock pulley
    Quote Originally Posted by blueguy View Post
    Explain that.
    This.
    You don't drop pulleys until your 100% knock free on the current one.
    IIRC you only had the car for a month or 2 why are so anxious to drop pulleys? Solve your knock issue and then drop pulleys. Or risk it and look forward to engine trouble.
    Oh and while your at it get rid of that 180tstat until your tuned for it.
    04 Comp G.
  4. #4 Re: getting kr on stock pulley
    antioch ill
    the logic is strong with this one
  5. #5 Re: getting kr on stock pulley
    Pulley envy is a dangerous thing
    T-Stat really doesn't bother anything other than giving crappier MPG's.
    I always run a 180* because I hate the hot temps these cars see at cruise when heat is their #1 enemy.
  6. #6 Re: getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    Ok so I stated the mods I have like I said I only see kr when I shift gears not sure if that's normal or not I've read stock gtps will see knock that's normal I have 0 knock till shift change so I'm asking ypu guys what can I do to eliminate knock if I already have all the supporting mods for a pulley drop? I hear a tune will help eliminate knock
  7. #7 Re: getting kr on stock pulley
    Poly mounts.
    Shift kit.
    04+ cars have a more aggressive timing curve anyways.
    Make sure the headers aren't making contact with anything under load. Could be false if it's only when the car shifts.
  8. #8 Re: getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    Shift kits.going.in Friday once my dormant pan comes in and hmm ill have to check under the car if the header is banging anything maybe its touching the transmission dipstick could that cause it I remember that it was super close toy header I wasn't able to bend it as much as i wanted
  9. #9 Re: getting kr on stock pulley
    Yea check the condition of your mounts. I have poly up top and hydraulic on the bottom works done for me. One thing to especially check with the SD is that the sway bar isn't hitting it. Easy and free fix is to flip it so its facing the other way.
    04 Comp G.
  10. #10 Re: getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    What part of the header would the sway bar be hitting ? Also what are signs of a bad mount I wouldn't mind buying the oily mounts for the front dogbones hopefully that would help
  11. #11 Re: getting kr on stock pulley
    What part of the header? Let's try the downpipe.
    Oily mounts?
    The hell are you talking about guy.
  12. #12 Re: getting kr on stock pulley
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    If u have all those mods without a tune and see 0 kr my question is do u have a wideband o2 sensor to check ur AFR.. tunes are no good without a wideband either! A proper setup of guages of a boost, wideband afr, and aeroforce will allow u to really see what's going on!!
  13. #13 Re: getting kr on stock pulley
    A wideband tune on a stock pulley will fix the KR that he has now...not likely...since he isn't getting KR except during shifts.
    Keep up.
  14. #14 Re: getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    My bad am on my phone poly mounts and ill check tomorrow to see if my sway bar is touching my header
  15. #15 Re: getting kr on stock pulley
    Yeah, get the poly uppers.
    Or just flip the stockers if you haven't.
    Will help a metric **** ton.
    I suggest reading the thread in my sig.
  16. #16 Re: getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    I've read your thread tons I'm going to swap back to my factory t stat let's hope I can cure this kr thanks for the help
  17. #17 Re: getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    Which company would yall recommend for poly mounts I see zzp has lowest price so far
  18. #18 Re: getting kr on stock pulley
    I had a terrible experience with ZZP upper poly mounts. I had the 2 piece design and every time I would throw it in a different gear or take accelerate from a light I would get this annoying ass clunk. Switched to Intense and I've been happy ever sense.
    Edit: spelling
    04 Comp G.
  19. #19 Re: getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    Alright ill check out .intenses
  20. #20 Re: getting kr on stock pulley
    Jun 2013
    Hollywood ,FL
    so i took a look at my headers on my lunch break i noticed tht my tranny dipstick is touching the crossover any special techniques to bending it while its still in the car?? could that cause false knock?? also i noticed my passenger side square upper mount moves back adn forth while the engine is at idle im guessing thats signs that that mount is bad because the driver side mount barely moves at engine idle
  1. 10 psi w/ stock pulley?!?
    By 97PAGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2011, 08:14 AM
