Thread: Belt And Pulley issue! NEED HELP ASAP!
Results 1 to 14 of 14
  1. #1 Re: Belt And Pulley issue! NEED HELP ASAP!
    you need a Gm p/s pump pulley puller to get your pulley off that shaft, then put that pulley on the new pump.
    easy enough job now that you can see the 2 bolts that hold the pump on lol
    you'll want to jack the front pass side up, take the wheel off, then un hook the 2 lines under the pump, have a pail to catch the fluid that will pour out. then take the pump off, swap the pulley, then put the new pump on.
    the pumps runs 40 bucks or so, and the puller you can rent. dont even think about using another puller, the GM p/s pulley puller is all you can use. or you'll be looking to buy a new pulley for the pump.
  2. #2 Re: Belt And Pulley issue! NEED HELP ASAP!
    gardner,mass
    Really..... i didnt have a problem with the puller i rent out at work.
    This style
    https://www.lefthanderchassis.com/pr.../233W87020.jpg
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: Belt And Pulley issue! NEED HELP ASAP!
    Quote Originally Posted by Ginseng View Post
    This style
    thats a Gm p/s pulley puller. same one i bought. with out that, you can forget getting it off.
  4. #4 Re: Belt And Pulley issue! NEED HELP ASAP!
    gardner,mass
    Any auto parts store rents them. Cap, autozone, advanced, ect..
  1. ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 08:26 PM
