Thread: Help Please!
Results 1 to 20 of 26
  1. #1 Help Please!
    Jan 2013
    Lexington, Indiana
    Okay so I have a 2000 Grand prix gt that has been converted over to a gtp. My only problem is I keep blowing motors. I'm just blew up the third motor yesterday and I'm running out of resources fast. The only thing I have done the same to each motor is the supercharger. Could there be something wrong with the supercharger that is blowing the motors up? It's running stock pulley and each motor has blown up under boost. I'm out of ideas here. Any info would be greatly appreciated. Thanks In advance.
  2. #2 Re: Help Please!
    antioch ill
    are you running 91 oct minimum
  3. #3 Re: Help Please!
    Jan 2013
    Lexington, Indiana
    Yes
  4. #4 Re: Help Please!
    May 2012
    Cedar Rapids, Iowa
    what condition are the motors in when you put them in? Are they high mileage?
  5. #5 Re: Help Please!
    Jan 2013
    Lexington, Indiana
    The first motor I put in had 80,000 After That one blew up I top swapped my other motor With 160K Bad Idea I know but I needed my car. And the third one had 130K But It had been taken care of
  6. #6 Re: Help Please!
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Do you have a scan gauge to see if your running lean or have knock?
  7. #7 Re: Help Please!
    Jan 2013
    Lexington, Indiana
    The computer wasn't sending any codes at all. If it helps any All three have spun rod bearings.
  8. #8 Re: Help Please!
    did you have your pcm tuned for a top swap?
  9. #9 Re: Help Please!
    May 2012
    Cedar Rapids, Iowa
    Were you losing coolant into the oil?
  10. #10 Re: Help Please!
    Jan 2013
    Lexington, Indiana
    Nope Oil didn't have anything in it except metal shavings from the bearings
  11. #11 Re: Help Please!
    Dec 2012
    Where 4T65E's were born
    So all 3 motors spun rod bearings? What are the odds of that? What oil were you running, and a dumb question maybe but was it always in the safe range? And was the temp always in a normal range?
    Sold.
  12. #12 Re: Help Please!
    Jan 2013
    Lexington, Indiana
    I was running 10w-30 oil. It was in the right range. And the motor was at normal operating temp. For all three motors
  13. #13 Re: Help Please!
    Who tuned your pcm for the SC motor?
  14. #14 Re: Help Please!
    did you get the pcm tuned? or did you switch the pcm? or just wired it up and make it run?
  15. #15 Re: Help Please!
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    http://www.grandprixforums.net/top-s...info-7763.html
    ^ cant hurt to read through this and make sure you have all the necessary items and swapping done
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  16. #16 Re: Help Please!
    Jan 2013
    Lexington, Indiana
    The wiring harness and pcm were out of a 99 Gtp
  17. #17 Re: Help Please!
    What year is the car?
  18. #18 Re: Help Please!
    Jan 2013
    Lexington, Indiana
    All three motors ran perfect until they were put under boost then the rod bearings went out
  19. #19 Re: Help Please!
    Jan 2013
    Lexington, Indiana
    My car is a 2000
  20. #20 Re: Help Please!
    As asked previously do you have any way to scan the car? Does the oil smell normal?
