You might want to take a look at your cam bearings when you pull the old cam. The bearings should be silver/grey with very little gold showing. It is common for the LIM gasket to leak coolant on the cam and wear out the bearings.... happened to me when I planned on doing a cam install. That project turned out into a full motor rebuild for me. Also like Bill said with a higher lift cam you will want stronger springs... usually 105's for a stage 1 type cam. I'd change the water pump and install the new aluminum elbows too. You might want to consider changing the hoses if they are the original ones.
