Thread: chirping/squeaking/clicking noise coming from engine area
Results 1 to 9 of 9
  1. #1 chirping/squeaking/clicking noise coming from engine area
    GT Level Member des19's Avatar
    May 2011
    Ontario
    04 gtp comp g
    just this morning this issue started never heard this in its lifetime.
    at first i would hear it at idle but after 15 min of driving i would only hear it if i got on the peeal. Sound/clicking increased (got more frequent) with rpm and clicking got more rapid from what i think is in the engine bay.
    any thoughts what it could be i have no idea atm.
  2. #2 Re: chirping/squeaking/clicking noise coming from engine area
    I'd think pulley or belt. You'd need to look under the hood to diagnose it .
  3. #3 Re: chirping/squeaking/clicking noise coming from engine area
    May 2011
    Ontario
    that is what initially came to mind will give a look later.
  4. #4 Re: chirping/squeaking/clicking noise coming from engine area
    Fire it up and use your mechanics stethescope to check the pulleys. Or put a couple drops of water on the belt while it's running. If the noise goes away..you know it's belt/pulley related.
  5. #5 Re: chirping/squeaking/clicking noise coming from engine area
    May 2011
    Ontario
    will give this a try later when have time thanks
  6. #6 Re: chirping/squeaking/clicking noise coming from engine area
    GTX Level Member cerick08GP's Avatar
    First thing I would check is the belt tensioner/pulley.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  7. #7 Re: chirping/squeaking/clicking noise coming from engine area
    May 2011
    Ontario
    opened up the hood today definately coming from a pulley and/or belt going to have it looked at friday. squeeking got very loud can hear it over everything now!
  8. #8 Re: chirping/squeaking/clicking noise coming from engine area
    Going to have it looked at? We are a forum here to help you learn how to do it yourself if, you'd like to try.
  9. #9 Re: chirping/squeaking/clicking noise coming from engine area
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Waterpump (since noone has said it yet).. Just a guess.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. Squeaking coming from front subframe area
    By 1filthygp in forum Brakes/Suspension/Chassis
    Last Post: 05-26-2013, 08:51 AM
  2. Clicking Coming From R&P Area & Rapid Thumping Sound While Driving
    By SliceTheRice in forum General Tech Discussion
    Last Post: 10-08-2012, 01:28 PM
  3. Having a clicking noise coming from the rear when I apply the brakes.
    By Bluemagic in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2012, 08:45 PM
  4. Loud rattling noise coming from belt area
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 10:06 PM
  5. Chirping noise coming from altenator/tensioner only when cold.
    By Beauty026201 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2010, 06:39 AM
