Thread: I need my MAF and injectors upgraded!!
Results 1 to 3 of 3
  1. #1 I need my MAF and injectors upgraded!!
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    So my injectors and MAF are almost maxed out probably and am looking into going to the junkyards to find cheap parts! What cars came with 39-42lb injectors and what cars came with the 85mm MAF ??
  2. #2 Re: I need my MAF and injectors upgraded!!
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    any lq4 engine is what ur looking for on the MAF side, but idk of any stock injector upgrades.
  3. #3 Re: I need my MAF and injectors upgraded!!
    Mustangs came with the green top 42lb injectors and Chevy 6.0 trucks had the maf. Although if you are doing this and want to change you can program.. many others used a similar maf, you just need the table.
  1. Upgraded UIM/LIM gasket time
    By 4fanintexas in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2013, 07:04 PM
  2. Upgraded Reverse lights
    By Doc Banger in forum Visual/Body Modifications
    Last Post: 12-18-2012, 01:57 PM
  3. Hud and upgraded dic install for '04 Gt1
    By Riviera in forum General Tech Discussion
    Last Post: 12-27-2010, 02:37 PM
  4. Upgraded to an A2A IC System.
    By Silver2kgtp in forum Turbo
    Last Post: 11-14-2010, 06:08 PM
  5. for those of you that changed. upgraded rad
    By kuntzie in forum General Tech Discussion
    Last Post: 07-04-2010, 09:24 PM
