Thread: Fuel pump recommendations
Results 1 to 5 of 5
  1. #1 Fuel pump recommendations
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Just like the title says... Looking for a good performance pump.
    I heard bad things about ZZP's pumps. Any recommendations appreciated.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: Fuel pump recommendations
    Money vortex synysterjoe's Avatar
    Mar 2013
    Columbus
    ZZP's "ZZP350" pump is a Chinese Walbro knock off that doesn't flow 350 lph, contrary to what the misleading name might suggest. Actually, they never give ACTUAL flow numbers anywhere in the description, just arbitrary "20%-30%" over stock.
    Intense's 255 Walbro pump actually flows 255 lph, comes with a 1 year warranty, is a proven, reliable, U.S. made pump that will flow enough to support almost any power. i'll be running one on E85. and its only about 10 bucks more expensive VS. ZZP's cheap Chinese pump for non-venturi. For guys with venturi style canisters, they are priced equally.
    TL;DR just get the Wally. INTENSE-Racing.com: Walbro 255lph Fuel Pump
  3. #3 Re: Fuel pump recommendations
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    +1 on the walbro. Great pump for the money
  4. #4 Re: Fuel pump recommendations
    Oct 2012
    New Jersey
    Thank you gents. Ordered!
  5. #5 Re: Fuel pump recommendations
    May 2008
    Schuyler, NE
    I would have went with the Racetronix, but the Walbro is almost the same thing.
  1. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  2. Fuel pump recommendations?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 07-01-2012, 05:31 PM
  3. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  4. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
