Thread: kr question
Results 1 to 10 of 10
  1. #1 kr question
    Mar 2013
    amherst
    Using. Torque pro I'm seeing 25-27° at cruise and 4.5-5.5 at WOT this is with a hai autolite 605. And a freshly cleaned TB if that makes any diffrence ? My question is the 25-27 a high number for just regular driving ? I know the 4.5-5.5 is somewhat in the midrange for WOT I think
  2. #2 Re: kr question
    Are you sure you know what numbers are what?
    Ignition Timing will vary from 25-38ish while at crusing speeds.
    Knock Retard from 4-6º on a 99% stock car is the normal to see.
  3. #3 Re: kr question
    Mar 2013
    amherst
    I'm looking at timing adv. On torque
  4. #4 Re: kr question
    At WOT timing on a stock car will be around the 14-15 range, but with KR it will go lower at points.
  5. #5 Re: kr question
    5* of timing is ridiculously low.
  6. #6 Re: kr question
    Mar 2013
    amherst
    Through looking into torque I found the Gm DL pid things and I found an actual KR part and it shows 0 at crusing and I got a few 3's a 2.5somethibg and a 4.5 . From your last post u said 5 is low ? So even with some +/- I'm guessing 5-6eta ? Does this sound right ?
  7. #7 Re: kr question
    4-6º of KR is somewhat the norm on a stock car.
  8. #8 Re: kr question
    5* of kr is high. 5* of timing is low
  9. #9 Re: kr question
    Mar 2013
    amherst
    Saw above a 4.5 sorry *
  10. #10 Re: kr question
    Mar 2013
    amherst
    Well I actually never saw a 4.5. I'm just adding a little due to if the apps slightly off or not calibrated 100%
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
