Thread: I'm worried about internal pressure after I/C install
Results 1 to 7 of 7
  1. #1 I'm worried about internal pressure after I/C install
    Slower, Lower Delaware
    I put on a S2 I/C from ZZP. There is a passage for the PVC valve cut into the ported LIM. If I got that clogged with sealer obviously the PVC system would not work as intended. Could that cause a rise in internal pressure? I replaced the valve cover gaskets last year when I did rockers. After the I/C install I am getting a little oil seepage from under the Valve cover gaskets. Could that be related?
  2. #2 Re: I'm worried about internal pressure after I/C install
    Which gaskets did you use and did you change the grommets?
  3. #3 Re: I'm worried about internal pressure after I/C install
    Gaskets came from ZZP and the grommets were replaced (Felpro).
  4. #4 Re: I'm worried about internal pressure after I/C install
    Max Cook
    Guest
    the ZZP valve cover gaskets only work with their aluminum valve covers. They pretty much suck with stock valve covers. If you're really worried about PCV, get a valve cover breather for additional insurance.
  5. #5 Re: I'm worried about internal pressure after I/C install
    I would think its the gaskets. I don't like the way those fit in the stock valve covers. Fit great in their polished covers..but not stockers.
  6. #6 Re: I'm worried about internal pressure after I/C install
    Thank you guys
  7. #7 Re: I'm worried about internal pressure after I/C install
    ZZP says a drive by wire needs programming to use a valve cover breather. Anyone know anything about that?
  1. Sunpro Sport ST Electric Oil Pressure Gauge Install
    By KZOO3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2012, 01:02 PM
  2. Oil pressure gauge install help please
    By szalajka05 in forum Audio, Security & Visual Electronics
    Last Post: 12-18-2011, 07:54 PM
  3. Mechanical Oil Pressure Gauge install
    By Frank4202 in forum General Tech Discussion
    Last Post: 04-30-2011, 10:19 PM
  4. how to install a oil pressure sender
    By Will5600 in forum General Tech Discussion
    Last Post: 04-08-2010, 07:01 AM
  5. worried plez help
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 08:58 AM
