Thread: l67 into a gen 2?
Results 1 to 4 of 4
  1. #1 l67 into a gen 2?
    May 2011
    ohio
    what do you need to switch over to put a l67 into a gen 2 grand prix
  2. #2 Re: l67 into a gen 2?
    Motor, pcm, wire harness, fab skills, researching skills, nunchuck skills, computer hacking skills.
    But for serious, don't you think trying to figure this out on your own is a better idea, because we can't spoon feed you this kind of knowledge. Maybe the info is out there, but more than likely you are going to have to do a ton of fab work to make stuff work.
  3. #3 Re: l67 into a gen 2?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  4. #4 Re: l67 into a gen 2?
    St. Louis
    zach, you plan on swapping an L67 engine/trans into a 1969-1972 GP?? That is truly different. Good luck on your project. Not sure how well it will move that big ol car compared to the 400 but it's worth a shot.
gen, l67
