Thread: GTP issues
Results 1 to 10 of 10
  1. #1 GTP issues
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    Hi everyone, I have a 2000 gtp, completely stock.
    Over the last week or so, I noticed that my engine temp would go above normal when I first start my car..but would drop down to normal after a little bit, and be fine until the next day. Sometimes it took me getting on the gas to get the temp to drop. Additional note, my low coolant light has been persistant despite me not actually being low. Last thursday, my temp rose and never came down. My resevoir has a whole in it..can't fill it above half. I normally checked my coolant level by how much was in my radiator. I pulled the cap thursday night while on the side of the road, and attempted to put more in thinking maybe it magically got drastically low somehow. I poured the coolant in, and as fast as I poured, you could see it coming out of the bottom of the car, but I did not look to see exactly where, I could tell it was in the area where the lower radiator hose went into the radiator.
    After the engine had cooled a bit, I went to put more coolant in to see exactly where it was leaking, but it did not this time. The car started up and drove the three miles home just fine, no miss, normal temps, etc. Replaced the lower radiator hose, the car now seems to be missing, also replaced the thermostat today, the car is not leaking that I can see, the system is pressurizing, but my low coolant light is still on and my temp kept rising again. Is there any ideas that could be causing these symptoms? Thanks in advance guys.
  2. #2 Re: GTP issues
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    Could it be the water pump, and for the randomly leaking idk. Have you replaced your Lim gasket?
  3. #3 Re: GTP issues
    Jul 2011
    Frederica, DE
    Update: overheating seems to be gone...its misfiring like a sum*****...can't hook a reader up because my obd ii won't communicate....tried a friends snap on scanner and it said something about overcurrent protection? Also I suspect I may have a bad radiator cap.. As far as the lim...I have not...can't say if it was before....its a Jy engine
    Update 2: took it for a spin around the block....can't get over 30-35 without the check engine light flashing....and started to smell burnt rubber in the car....I am not qualified for this...I am in over my head....probably taking it to a shop in the near future
    Sent from my SGH-I777 using Tapatalk 2
  4. #4 Re: GTP issues
    Replace the cig lighter fuse so the code reader works then tell us the codes.
  5. #5 Re: GTP issues
    Jul 2011
    Frederica, DE
    I checked that fuse..its not blown?
  6. #6 Re: GTP issues
    Swap it just to make sure
  7. #7 Re: GTP issues
    Jul 2011
    Frederica, DE
    OK changed that fuse....no different. "Communication line shut down due to over current protection on VE line"
  8. #8 Re: GTP issues
    That's weird. Never heard of that before.
  9. #9 Re: GTP issues
    Jul 2011
    Frederica, DE
    Neither have I, I even googled it, and nothing... going to call the shop tomorrow...
  10. #10 Re: GTP issues
    Jul 2011
    Frederica, DE
    update: took it to the shop, had a bad ignition coil....runs 1 million times better...have a bad coolant sensor though
  1. New here and having some issues
    By bmed10 in forum Introductions/Noob Questions
    Last Post: 09-19-2012, 12:44 AM
  2. TCS/ABS issues?
    By Iced Iridium in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2012, 06:51 PM
  3. MAF issues?
    By Sl33p3rGt in forum General Tech Discussion
    Last Post: 07-18-2011, 05:40 PM
  4. a/c issues: help please
    By us Sgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 10:33 AM
  5. 99 gtp issues
    By Dan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2009, 10:29 PM
