Quote Originally Posted by PlanBRacing View Post
Thanks for the reply, haven't checked the maf, tps.. Would this cause the car not to pump fuel? I replaced the fuel pump. But later I realized there was no electricity going to the pump... When I pulled out the fuel pump relay and inserted a small gauge wire into two relay ports the pump came on car would not start though... It's not a relay, fuse, etc...
Is the fuel pump a oem fuel pump? New? used? Ebay? Did you put gas in the tank like about 15 20 bucks worth? Sounds like you aren't putting enough gas in the car Man.. I out about 20 bucks in then see .. maf and tps won't cause the car to start trust me I would also do a fuel pump rewire since you have it in your hands..keep us posted
Sent from my SAMSUNG-SGH-I747 using Tapatalk
