Thread: To mod, or to rebuild? That is the question.. The $2000 question
Results 41 to 60 of 71
  1. #1 Re: To mod, or to rebuild? That is the question.. The $2000 question
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    and does anyone actually sell the pre bent dipstick? Is It just the trans stick, or the oil as well?
  2. #2 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    Is there a need to remove the EGR and use the Block off plates?
  3. #3 Re: To mod, or to rebuild? That is the question.. The $2000 question
    trans dip stick can be bent, but you can also buy a flexible one (my recommendation) to replace it and it'll bend however you want.
    and you don't have to remove the EGR, but a lot of people do to clean up the engine bay. you'll need a way to set the code to no report, though.
  4. #4 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Clamps, flex, o2 extension, reuse stock gaskets or get Felpros. Get some copper rtv just in case..Dp isn't to much of a issue just watch where you drive. Removing egr is optional..will set 2 codes. I removed mine to clean up the bay a bit, keeps my TB cleaner, and weight reduction cuz racekar.
    04 Comp G.
  5. #5 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    Thanks again guys. And comp if you said you drove on that modded PCM with a stock setup I'm not to worried about it for now. I'm just worried about something leaking on the dipstick as I was reading on gpona that some ppl were kinking the tube and needed a o ring for the bottom of the dipstick, along with having mounting issues up front were the passenger side fan motor was in the way of the header, broken a/c line trying to bend it down. Etc etc. In case you didn't notice I'm pretty cautious lol
  6. #6 Re: To mod, or to rebuild? That is the question.. The $2000 question
    I had to remove the metal man shroud. The ac line unless your hulk I don't see how you can break it. What I did was grab and wrap it around the line and then put a little body weight on it to slowly bend it down. Take your time and don't put to much weight on it. Then take the front headers and mock it up to make sure it clears the line. As far as the trans and oil duo stick I removed the trans stick (put a oil catch pan underneath it, it will leak a bit of trans fluid) for the oil stick I removed that and left the tubing and just slowly bent it out the way. I didn't have to completed remove it. Also where the front o2 sits on the headers you may want to bash in the firewall a bit so that the o2 doesn't rub..I didn't have the issue but other guys have and you may have to flip your sway bar.
    Overall it's not a bad job yea there's a few kinks to workout but spending $200 on headers vs the $500-600 for vendors it's expected.
    04 Comp G.
  7. #7 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    Any issues with them leaking or blowing out gaskets?
  8. #8 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nope...use your stock gaskets and or Felpros and three out the crappy ones that come with them. Use some copper rtv around the joints and once you use the band clamps your should have a great seal.
    04 Comp G.
  9. #9 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    My car looks pretty clean and rust free underneath but would I be safe just picking up new nuts for the head studs? Or any other hardware just to be on the safe side
  10. #10 Re: To mod, or to rebuild? That is the question.. The $2000 question
    gardner,mass
    i would grab new ones where the headers meet the resinator flange. Also your gonna need to get 2 spark plug non foulers from your local parts store for the nonfouler trick on your rear o2 sensor or you will be dumping fuel liek crazy
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  11. #11 Re: To mod, or to rebuild? That is the question.. The $2000 question
    You should be able to reuse the head studs...I replaced mine with some bolts from homedepot because I had the car apart for awhile I misplaced the studs. I did however replace the nuts that held the header flange and resonator together. for the 2 nuts I just bought Dorman #03142 and used the nuts out of there.
    Forgot to mention the fouler trick like Ginseng said
    How to install the spark plug anti-foulers to remove the ses or cel light - evolutionm.net
    04 Comp G.
  12. #12 Re: To mod, or to rebuild? That is the question.. The $2000 question
    I have no non fouler or rear o2 and have no problem with it at all so you might be fine there.
  13. #13 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    Do you still need the non fouler if you have a tuned / canned PCM with it tuned out? I ordered a overkill PCM 2 days ago but haven't heard back from will yet
  14. #14 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Quote Originally Posted by comatoast View Post
    nope
    04 Comp G.
  15. #15 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    Great ill just let him know what I need when I hear back from him.
  16. #16 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Don't forget to tell him to delete all the egr codes if you plan on removing that as well.
    04 Comp G.
  17. #17 Re: To mod, or to rebuild? That is the question.. The $2000 question
    May 2013
    Upstate NY
    Do you lose gas mileage when deleting the EGR? I've heard you lose 1-2mpg.
    04 CompG, black HAI, 180*, TR55s, custom tune by me, SD headers soon
    04 CompG, fusion orange, all stock
    99 GTP, red, coupe, 3.4, SLP exhaust, basic mods, PB 13.56, SOLD in 09.
  18. #18 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Some guys report a slight lose some say its the same if not better. Shouldn't make much of a noticeable difference especially if u tune for it.
    04 Comp G.
  19. #19 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Less crap getting into the TB = a win for me. Also lets crap in the bay and less weight = more win.
    So I'm pro to deleting the egr unless you got emission testing.
    04 Comp G.
  20. #20 Re: To mod, or to rebuild? That is the question.. The $2000 question
    May 2013
    Upstate NY
    I'm all for it too, I just wanted to make sure it wasn't gonna thrash my gas mileage. Not that I bought my car for the gas mileage but it is a plus. The EGR deal sounds like my brothers 2011 cummins. They say 99% of the problems those 6.7 cummins motors have are caused by the EGR dumping soot back into the motor.
  1. 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2013, 01:24 PM
  2. Caliper rebuild question
    By Logan541 in forum General Tech Discussion
    Last Post: 10-27-2012, 03:55 PM
  3. Pre-Branson Rebuild Question
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 04:00 PM
  4. question on Fbody caliper pistons rebuild
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2008, 12:08 PM
  5. Tranny rebuild question
    By bula81069 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2008, 05:57 PM
