Thread: ENGINE TEAR-DOWN - pics and need advice
Results 1 to 14 of 14
  1. #1 ENGINE TEAR-DOWN - pics and need advice
    Minot AFB
    Background of what happened: I was on the highway when cylinder 6 started misfiring. I must have been in boost at the time because the next thing that happened was a loud boom, smoke, the engine stalled. It started up again with lots of white smoke coming out the tail pipe and metal clunking noises; at that point I knew I wasn't going anywhere.
    Here are some pictures I took tonight, as you can tell the push-rod is bent and the valve spring is broken.
    What am I looking at here? What can I expect as I take the head off? This is the first time I'll be attempting to fix something like this so any and all advice is appreciated. Also, when I drained the oil, coolant came out first then oil mixed with coolant. Almost filled up my 15 quart oil pan......................
    ENGINE TEAR-DOWN - pics and need advice Attached Images
  2. #2 Re: ENGINE TEAR-DOWN - pics and need advice
    Minot AFB
  3. #3 Re: ENGINE TEAR-DOWN - pics and need advice
    Motors probably trashed if the valve beat up the piston
  4. #4 Re: ENGINE TEAR-DOWN - pics and need advice
    HUDSON
    Either the lower intake manifold gasket failed and water got into the intake port and the crankcase, or you blew a head gasket, and the motor hydraulic action of the water cannot be compresses. Or the valve dropped down into the cylinder and punched a hole in the block allowing water into that cylinder. It looks like either the retainer or the keepers failed and allowed the valve to drop. Either way, don't waste time working on it, just replace with another known good engine.
  5. #5 Re: ENGINE TEAR-DOWN - pics and need advice
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Cheap enough to pick up a used block also much less hassle then trying to rebuild these.
    97 Bonneville SE Not so much a 97 anymore
  6. #6 Re: ENGINE TEAR-DOWN - pics and need advice
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    You guys have little faith....I bought a Buick Park Ave that had a broken valve spring. Yes the bent pushrod doesn't look good but IMO it's totally worth a shot to put on new spring, rocker, pushrod....and run a compression test. Would be a super cheap fix and worth a shot.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  7. #7 Re: ENGINE TEAR-DOWN - pics and need advice
    St. Louis
    ^^ This statement right here is why he should most likely be looking for a used motor. I'd be willing to bet that the piston is trashed once he gets that head off. Not saying that it's not saveable, but it doesn't sound good, especially if he was in boost. Higher RPMS+part failure= no good usually.
  8. #8 Re: ENGINE TEAR-DOWN - pics and need advice
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Why not just take the spark plug out and take a look in there to see waht the piston looks like before you even bother with taking the head off?
  9. #9 Re: ENGINE TEAR-DOWN - pics and need advice
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Borescope it...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #10 Re: ENGINE TEAR-DOWN - pics and need advice
    Minot AFB
    Quote Originally Posted by addzradd View Post
    I fished out metal pieces from the cylinder thru the spark plug hole. So much coolant in the system and everything else I have taken off so far not showing any sign of letting coolant thru leads me to believe that the head gasket is blown or worse. So the head is going to come off either way. We will see.im hoping for the best! If anything ill be shopping for a used short block and head. Or a new motor. What do you guys suggest?
  11. #11 Re: ENGINE TEAR-DOWN - pics and need advice
    Grand Island, Nebraska
    Turn it into a coffee table. coolant in oil is very bad.
  12. #12 Re: ENGINE TEAR-DOWN - pics and need advice
    Just throw a new motor in it
  13. #13 Re: ENGINE TEAR-DOWN - pics and need advice
    Apr 2011
    Columbus, OH
    When I was at work I couldn't see the pics all that well...and I needed to read the whole post.
    I retract my earlier statement...start looking for a used motor.
  14. #14 Re: ENGINE TEAR-DOWN - pics and need advice
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    JB weld.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  1. Pics/advice on FMIC installation
    By DJNight2k in forum Turbo
    Last Post: 05-11-2013, 08:34 AM
  2. Replies: 26
    Last Post: 04-29-2012, 07:46 PM
  3. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  4. Pics of my engine tear down dial up user beware
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-13-2009, 11:09 PM
  5. Pics of the tear down and paint
    Last Post: 08-11-2009, 04:11 PM
