Thread: Need help drilling hole for PCV in IC core.
Results 1 to 5 of 5
  1. #1 Need help drilling hole for PCV in IC core.
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I have a gen 3 SSIC core on my GEN5 setup that is blocked and needs to be drilled.
    To drill it I was going to stick a drill down the pcv nipple and mark it and take the car apart and drill the core with a press. Is that I will need to do? I have a zzp LIM if that helps at all..
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Need help drilling hole for PCV in IC core.
    Apr 2012
    Middletown DE
    bumpity for morning crowd
    1993 Oldmobile 88
  3. #3 Re: Need help drilling hole for PCV in IC core.
    HUDSON
    Couldnt you use the gasket to locate the hole?
  4. #4 Re: Need help drilling hole for PCV in IC core.
    Apr 2012
    Middletown DE
    Quote Originally Posted by QUICKSILVER462 View Post
    damn you and your logical thinking.
    1993 Oldmobile 88
  5. #5 Re: Need help drilling hole for PCV in IC core.
    HUDSON
    If only my (logical thinking) could happen more often.
  1. Drilling a hole in the firewall for extra gauges/electronics?
    By Wotgtp in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2013, 11:57 AM
  2. HELP! Hissing sound after drilling though firewall
    By Jomamma in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2012, 11:26 PM
  3. Drilling and Tapping Phenolic Spacer
    By ls1camino in forum General Tech Discussion
    Last Post: 06-14-2011, 07:19 PM
  4. Drilling a Tstat????
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 06:49 PM
  5. Drilling holes in the trunk???
    By MysticStyl3z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2008, 10:58 AM
