Thread: Duble roller timing chain removal?
Results 1 to 20 of 21
  1. #1 Duble roller timing chain removal?
    SE Level Member Adam D's Avatar
    Jan 2013
    grand rapids mi
    Can someone tell me how to remove the double roller timing chain?
  2. #2 Re: Duble roller timing chain removal?
    Pull the gear off.
  3. #3 Re: Duble roller timing chain removal?
    Jan 2013
    grand rapids mi
    The gear dont pull off its on a blown motor i assumed this was pressed on tighter then the original or if it was jammed on because of a piston smashig a valve bendin a pushrod
  4. #4 Re: Duble roller timing chain removal?
    The timing gear doesn't come off? Should have a bolt on it right?
  5. #5 Re: Duble roller timing chain removal?
    Jan 2013
    grand rapids mi
    Yeah i removed the bolt? Should this come off like the factory timing set?
  6. #6 Re: Duble roller timing chain removal?
    Honestly i don't know I've only messed with stock sets I just assumed they were the same
  7. #7 Re: Duble roller timing chain removal?
    Jan 2013
    grand rapids mi
    Me 2 until i couldnt get it off lol
  8. #8 Re: Duble roller timing chain removal?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    You have to pry the crank sprocket off, it does not just slide off like the single rollers. Screw driver behind it on both sides and work it off or a pry bar. As you easy it off the cam sprocket will come along with it if you do them together.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  9. #9 Re: Duble roller timing chain removal?
    Jan 2013
    grand rapids mi
    I was able to remove the cam sprocket with a pulley puller.then removing the crank from the block to get the timing set apart. I still need to remove the crank sprocket. Im gonna try that tommorow with a cou
  10. #10 Re: Duble roller timing chain removal?
    Jan 2013
    grand rapids mi
    * couple screw drivers to pry it off i cant fit the pulley puller on it.
  11. #11 Re: Duble roller timing chain removal?
    Nov 2009
    Tennessee
    There's not much pressure on it. When I installed mine I just used a piece of wood and a hammer with slights taps and the crank sprocket went right on. I can only assume to remove it, it won't take much.
  12. #12 Re: Duble roller timing chain removal?
    Jan 2013
    grand rapids mi
    This happened and im guessing thats why im having trouble :what:
  13. #13 Re: Duble roller timing chain removal?
    Looks fine to me lol
  14. #14 Re: Duble roller timing chain removal?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    it looks like someone done put tinfoil in your motor!!!!
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  15. #15 Re: Duble roller timing chain removal?
    Jan 2013
    grand rapids mi
    Thats from one grenaded piston lol
  16. #16 Re: Duble roller timing chain removal?
    Nov 2011
    NY
    Holy cow...
    Im always cringing when I see this stuff... Lol
  17. #17 Re: Duble roller timing chain removal?
    Sep 2011
    palm harbor florida
    seriously what the hell is that
  18. #18 Re: Duble roller timing chain removal?
    Jan 2013
    grand rapids mi
    Quote Originally Posted by Doug 97 gtp View Post
    That is a blown up piston
  19. #19 Re: Duble roller timing chain removal?
    Sep 2011
    palm harbor florida
    it seriously looks like tinfoil broken up into a million pieces
  20. #20 Re: Duble roller timing chain removal?
    5 cylinders get better gas mileage?
  1. Roller Master Double Timing Chain
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2012, 08:28 AM
  2. My Roll-Master double roller timing chain after 30K....
    By copgtp in forum General Tech Discussion
    Last Post: 03-27-2011, 12:06 PM
  3. help me with a double roller timing chain
    By foursixer in forum General Tech Discussion
    Last Post: 12-20-2010, 12:20 PM
