Thread: Slight smoking coming off front exhaust manifold
Results 1 to 15 of 15
  1. #1 Slight smoking coming off front exhaust manifold
    Banned
    Jan 2013
    Colorado
    After driving the car for maybe a few miles, when I got there I could smell something. Not sure what is was exactly but I popped the hood and there was a little bit of smoke coming off the front exhaust manifold. There is a small oil leak somewhere but this is coming off nearly the top of the manifold. Any idea what it could be?
  2. #2 Re: Slight smoking coming off front exhaust manifold
    the valve cover gaskets are leaking, change them.
  3. #3 Re: Slight smoking coming off front exhaust manifold
    Banned
    Jan 2013
    Colorado
    valve cover or manifold gasket?
  4. #4 Re: Slight smoking coming off front exhaust manifold
    valve cover. both front and back should be changed before you catch fire and burn the car to the ground.
  5. #5 Re: Slight smoking coming off front exhaust manifold
    Banned
    Jan 2013
    Colorado
    You really think there is a high risk of it catching fire? I might try to hold out on changing that gasket until I tear down the entire engine to put in the cams amongst other things.
  6. #6 Re: Slight smoking coming off front exhaust manifold
    change em now. they are reusable later on, they are rubber like.
    and yes you can catch fire. its part of the GM recall.
  7. #7 Re: Slight smoking coming off front exhaust manifold
    Feb 2013
    37.295091, -121.930053
    i will laugh at you if it burns up. dont be that guy
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: Slight smoking coming off front exhaust manifold
    Banned
    Jan 2013
    Colorado
    Damn...ugh well this is gonna be annoying. Any write ups for changing the valve cover gaskets?
  9. #9 Re: Slight smoking coming off front exhaust manifold
    front one is easy.
    pull the dog bones, the sc tensioner, the coil pack and dog bone mount, the wires have a small bolt in the harness, 8 mm iirc. then take the v/c bolts out, clean the head where the gasket sits with brake cleaner on a rag. and clean the valve cover as well.
    put the new grommets in the v/c and the new gasket, then snug the bolts up nice, dont over tighten them, they only go so far and can break off easy.
  10. #10 Re: Slight smoking coming off front exhaust manifold
    Feb 2013
    also if your not to sure go to a shop and have them change them. but i trust you can use hand tools and do this your self.
  11. #11 Re: Slight smoking coming off front exhaust manifold
    Banned
    Jan 2013
    Colorado
    Well if it blows before saturday then that's going to be quite unfortunate.
  12. #12 Re: Slight smoking coming off front exhaust manifold
    you need a deep 13 mm and a 3/8 or 10 mm, a 8 mm, and i believe thats about it. oh and a 15 mm to get the sc belt off and the dog bones.
    it would need to leak pretty good to catch fire. the chance is always there tho. sometimes they leak with out hitting the manifolds, but if you see and smell smoke, they should be changed asap.
  13. #13 Re: Slight smoking coming off front exhaust manifold
    Feb 2013
    just follow this advise and get it fixed or you will lose your car. the 3.8L catches fire all to often from oil build up and you not changing your valve cover gaskets are just asking for your car to no longer be driving. This problem is very preventable and if you dont FIX IT as of NOW then you will not have your car to drive and you will be on foot. i can keep going on if you like so stop fing around and FIX IT.
  14. #14 Re: Slight smoking coming off front exhaust manifold
    Banned
    Jan 2013
    Colorado
    Well I could only smell it outside the car, not inside it.
  15. #15 Re: Slight smoking coming off front exhaust manifold
    Feb 2013
    dont matter it will start with the exhaust manifold getting over 1000°F and a oil leak that just keeps getting worse then you have a nice fire. hope you have some marshmellows and a few sticks ready!!! all the car fires i have ever seen could have been prevented and you will lose your car over something dumb. hope you have a fire extingusher and your fast on your feet.
  1. Front Exhaust Manifold Question
    By Shandley in forum General Grand Prix Discussion
    Last Post: 10-04-2012, 11:12 AM
  2. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  3. Oil coming out front exaust manifold
    By GrandPrixHelp in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-16-2011, 04:39 PM
