Thread: Coil pack testing
Results 1 to 11 of 11
  1. #1 Coil pack testing
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    I seen a post on here about testing the coil packs with a multi meter,but didnt work like they exsplained but my multimeter has volts ac,volts dc,millivolts dc,resistance,diode test and 2 current settings,which do I use and what should my readings be
  2. #2 Re: Coil pack testing
    A link to the post would be great
  3. #3 Re: Coil pack testing
    SWPA
    Unplug the wire from the coil pack, stick your fnger where the plug wire goes and have someone crank the engine. That will tell you if it works or not.
    BTW, don't do that. It HURTS.
  4. #4 Re: Coil pack testing
    Jul 2010
    I'll try to find the post and the car was running and I pulled the cable and it shocked me like crazy
  5. #5 Re: Coil pack testing
    Jul 2010
    I can't find the post now,I'm on my phone,but how do I test them and what setting do I use,I listed them above
  6. #6 Re: Coil pack testing
    good news..first off..you survived, secondly..that wire is working good!
  7. #7 Re: Coil pack testing
    Dec 2010
    DMV
    Hey sorry to thread jack lol but Mr bill I'm trying to message you but because your so awesome your inbox is full lol. Could ya help me out and clear one so I can send one? Thanks.
    Carry on and my apologies
    Sent from my HTC One using Tapatalk 2
  8. #8 Re: Coil pack testing
    Jul 2010
    It made my arm num lol,it knocked me back about 2 feet
  9. #9 Re: Coil pack testing
    That's a pretty good coil then.
  10. #10 Re: Coil pack testing
    Minnesota
    Take the plug wires off both terminals on one coil and crank the car over. If it arcs between the two then the coil should be good. You could still test it with a multi-meter if you really want to though.
  11. #11 Re: Coil pack testing
    Jul 2010
    I'll try it shortly
  1. coil pack
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-18-2012, 02:57 PM
  2. Coil pack question
    By Logan541 in forum General Tech Discussion
    Last Post: 12-31-2011, 08:45 PM
  3. coil pack
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-13-2010, 12:22 AM
