Thread: P0300 and #6 misfire only happens while it boost
Results 1 to 20 of 31
  1. #1 P0300 and #6 misfire only happens while it boost
    Jun 2013
    Greenville, South Carolina
    New to this forum but not new to the cars. I have a 2000 GTP and just rolled over 150,000 miles on it. I just installed new coolant elbows, Egr valve, pads and rotors, and hub bearings on driver side front. I am not sure if the LIM gasket has ever been replaced with the new metal one. But I Got the #6 misfire code about 2 monthes ago so i replaced the plugs and wires. And just this past weekend i done all the other work listed above. Now i am getting the dreaded P0300 code and the #6 misfire code also. It only throws the code when i go into boost(passing some one on the highway)and while going up hill when the engine is under a good load(like when in overdrive it builds boost when going up hill). so i am thinking maybe the 3/6 coil pack or maybe a vac leak. Greatful for any replies Thanks
  2. #2 Re: P0300 and #6 misfire only happens while it boost
    Which plugs did you use?
  3. #3 Re: P0300 and #6 misfire only happens while it boost
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Before you buy a new coil you can swap it with another one and see if the misfire moves to another cyl.
  4. #4 Re: P0300 and #6 misfire only happens while it boost
    Daytona, florida
    I agree here too. Several people have reported problems useing platinum plugs in these cars.
  5. #5 Re: P0300 and #6 misfire only happens while it boost
    Jun 2013
    OEM AC delco plugs is what I used and I checked all of the vac lines on top of the motor and didn't see any ceacks or breaks. What is beat to use for vac leaks carb cleaner ir starter fluid? The plugs have been invfir around a month and haven't had any problem until now
  6. #6 Re: P0300 and #6 misfire only happens while it boost
    Try swapping the coil around with another like said above.
    If that doesnt work, I be leading towards it having a bad ICM.
  7. #7 Re: P0300 and #6 misfire only happens while it boost
    I had a p0306 on my gtp and just swapped the coil out for a known good one and all was well.
  8. #8 Re: P0300 and #6 misfire only happens while it boost
    Jun 2013
    Ok fellows this is what I got when I changed coils. The 4 and 6 terminal ends on the coil packs was rusted up so I took some sand paper and cleaned them and I have got the # 6 misfire code yet but I am still getting the blinking SES light. It is running alittke better but is still having a slight misfire I will know more this after noon when I drive home from work thanks again for all of your replys
  9. #9 Re: P0300 and #6 misfire only happens while it boost
    check the spark plug for damage yet? maybe its smashed, (aka chipped piston) or it got cracked when you put it in.
  10. #10 Re: P0300 and #6 misfire only happens while it boost
    Jun 2013
    I will check the plug tomorrow but the car is not smoking at all. I switched the coil and it is still throwing the misfire on #6 and the mutiple misfire code like i said above the 4 and 6 terminal ends on the coil pack were rusty and i cleaned them but still the same problem. what is really getting me is that it runs like a champ until you press the gas pedal enough for the supercharger to start building boost and then it starts misfireing. When I took the 2 bolts out of the 2 coil packs i switched the coil packs them selfs were loose(once the 2 bolts where out i just picked them up). < I have never had to mess with the coils so i am not sure if that is normal.
  11. #11 Re: P0300 and #6 misfire only happens while it boost
    any chance you used platinum plugs? you said oem, but that could mean anything really.
    you want iridium plugs, or copper plugs.
  12. #12 Re: P0300 and #6 misfire only happens while it boost
    Jun 2013
    fairly sure i used copper but couldn't say 100% but i am pretty sure because i have already read up on how these engines don't like the platinum plugs. and i had the same #6 misfire code before i changed plugs and after i changed them it ran fine until now(around a month). Could a bad lower intake cause the P0300? the oil looks fine and so does the coolant. Maybe a bad plenium gasket? I just replaced the fuel pump about 5-6 months ago.
  13. #13 Re: P0300 and #6 misfire only happens while it boost
    Jun 2013
    oh i am also having trouble getting the computer to relearn the position of the egr valve P1404. Tips?
  14. #14 Re: P0300 and #6 misfire only happens while it boost
    could be a clogged cat, that can cause a misfire and the flashing cel
    how much did you pay for the plugs, very little, they are copper, a lot, plats.
  15. #15 Re: P0300 and #6 misfire only happens while it boost
    Jun 2013
    around 3 bucks a piece i think they were cheap. How can i tell if the cat is clogged?
  16. #16 Re: P0300 and #6 misfire only happens while it boost
    well for starters, has the car been feel more and more gutless? like slowly loosing power over time?
    you can bang on it, if you hear it rattling its broken.
    or drive it hard for a bit at night, then stop and look at it. if its glowing red its clogged.
    then theres the old pull the o2 sensor out of the rear manifold see if it runs better. it makes a hell of a exhaust leak but if the car re gains some power the cat is clogged.
  17. #17 Re: P0300 and #6 misfire only happens while it boost
    Jun 2013
    when i press on the pedal like to pass some one i get a fuel smell in the cabin of the car but it is not raw fuel smells kinda like half burn exhaust. like it is running really rich.
  18. #18 Re: P0300 and #6 misfire only happens while it boost
    does it sound like a vacuum cleaner with a full bag? like it cant take air when you floor it? is the engine running hotter then it used to?
  19. #19 Re: P0300 and #6 misfire only happens while it boost
    Jun 2013
    the engine temp is the same but when you floor it it wants to cut back and sputter a bit
  20. #20 Re: P0300 and #6 misfire only happens while it boost
    only way to find out is to poke around some. like i mentioned.
    if the exhaust stinks bad that could be the cat as well clogged up.
  1. P0300 Code. Random Misfire NEED HELP!
    By JcGTP39 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2011, 10:12 PM
  2. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
  3. Code p0300 misfire caused by cat?
    By randywalsh in forum General Tech Discussion
    Last Post: 09-05-2011, 09:44 PM
  4. random misfire P0300, many new parts
    By MarkB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 11:10 PM
  5. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
