Thread: running 30*+ spark advance
Results 1 to 3 of 3
  1. #1 running 30*+ spark advance
    Aug 2012
    RI
    Just bought myself a scanner and while going through the live data I noticed I was running anywhere between 20-30+* spark advance. I'll be perfectly honest and say I don't know anything in regards to this, or if it has any correlation to knock. The car is close to stock. It only has a few aftermarket parts which are, spark plugs one degree cooler, 180* thermostat, new down pipe and cat back, and a CAI. Everything else is OEM parts.
    SO now that you got the background info, My question is if this spark advance is normal for essentially a bone stock car.
  2. #2 Re: running 30*+ spark advance
    GTP Level Member
    Pittsburgh
    While Crusing down the highway under light to moderate throttle, that is normal.
    Under WOT you should see about 15* given you dont have any KR
    2003 SSEi,
  3. #3 Re: running 30*+ spark advance
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Well first thing, take those colder plugs out. They are not needed. You want to run the hottest spark possible. AL606's Copper Core is what you want. Iridium's are fine as well, but do not get platinum.
    Getting 20-30* of timing (IGN. Advance) is perfectly normal for highway cruising.
    When going WOT you should anywhere between 14-16* on a stock car, and like Pat said, that is if you are KR free. If your car is Knocking, the PCM will pull timing to help prevent KR.
  1. what is timming advance?
    By asite57 in forum General Tech Discussion
    Last Post: 04-17-2012, 10:07 PM
  2. Hey all, and THANKS in advance:)
    By rschap1 in forum Introductions/Noob Questions
    Last Post: 10-17-2011, 02:32 PM
  3. Just saved over 50% at Advance and you can too!
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 09-08-2011, 03:27 PM
  4. oem or advance auto?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 06-23-2011, 11:42 AM
  5. what is ignition advance
    By xsvtank in forum General Tech Discussion
    Last Post: 06-17-2010, 10:09 PM
